Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca tv my rca d52w20 colors are 3d
  • Anonymous Aug 27, 2008
    there are 3 different colors piacture doesnt look right it looks like its not lined up right please help.....
    Genius:
  • 1,030 Answers
This is a indication of what is known as a convergence problem. this tv has three projection tubes and all the tubes must converge to the same spot on the screen. The first question that needs too be asked is in customer setup menu do you have the convergence option. if not it is a special fuse called fl231. and lt the repair is not all that dificult if you can get the fuse and can solder. if you have this option try autoconvergence option first. then try both red and blue convergence. if the crosshairs move at all then may be a cuircit board called the convergence amp. if not then it may be a convegence power board.
Posted on Sep 10, 2008
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Question - What would cause the colors to be off..meaning..it looks almost 3D and with widescreen shows the black on the top and bottow bows into the main area of the screen. Any ideas?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.The tv convergence board must be replace all these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Dec 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY TV WENT BLURRY AND DOUBLE..WHAT SHOULD I DO?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv looks like it is in 3D without 3D glasses, there are also some wavy color lines at the top of the screen
Most likely cause is FL231 and DL231 having failed. You can get the repair kit called ITC222 & ITC222A convergence repair kit from www.tvrepairworld.com which has the components and also includes the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv is showing 3d colors
Go to menu then setup if you do not see convergence you have a blowed fuse FL231 on bottom board to the left side this is your deflection board on right side of your (FBT) flyback Transfomer are 3 Fuses in aroll they look like small brown tirangler caps but are Fuses it will be the one in the middle Call Partstore.com !-866-925-7278 or look it up online.
Nov 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture looks like its 3D what is the problem
The D52W20 had an issue with solder joints around the flyback. When you take the back off the flyback is on the very left closes to the back of the tv and has a large red wire coming out of it. Looking from the top down you will see three small orange rectangles in a row. These are fuses and one of them is going to be opened.
All you have to do is resolder the pins on the flyback and replace the fuse and you should regain convergence.
Jun 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture looks like it's in 3D
Your convergence is off. You should have a convergence adjustment feature on the menu screen. Very easy to follow.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken TV
you will need a convergence amp board or a convergence power supply board depending on wether its one color out of alignment or all of them. Let me know what color or colors are out of alignment and I can help you out with board selection.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
