Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
BOBBIN SLIPPING AND STOP EMBROIDERY
I HAVE QUANTUM FUTURA CE -200, AFTER 4 REPAIR BILLS ,(SINGER CERT. TECH.), I'M FURIOUS, WHAT TO DO NEXT? THE BOBBIN HAS SLIPPED AND JAMMED ORDERS TEARING THE FABRIC AT TIMES, I 'VE HAD TO REPLACE CUSTOMERS GARMENTS.......I HAVE ORDERS PENDING NOW ...AND THE DARN MACHINE BOBBIN CARRIAGE C OMES COMPLETELY OUT.
  • 323 Answers
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Posted on Aug 28, 2008
When I thread the bobbin, code 88 flashes, what is that?
Try zero your embroidery hoop carriage by off/on your machine before your next application, if no result disconect your embroidery unit and connect back again ensuring it is properly connected. Hope the problem can be solved.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200
since it is a embroidery machine I would suggest the technican
to be on the safe side
Jun 03, 2012 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
When I go to fill my bobbin spool, the machine just beeps at me. I've tried everything. Please help!
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
Aug 22, 2011 | Singer CE-200 Quantum Futura Computerized...
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
Jan 18, 2011 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
220 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
