Question about Dell OptiPlex GX110 PC Desktop
Need to use a telephone line
No where to put telephone line on cpu
  • Dell Master
  • 3,051 Answers
That is probably because their is no modem card installed on the computer you will need to get one walmart has them ok hope this helps some best regards mike
Posted on Aug 25, 2008
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
I cannot sent or receive a fax. If I sent a fax, I get the report with NG, not sent. Where shall I connect the telephone line cable from the printer to the telephone switch, there are three...
Take normal telephone cable(direct line )Put it into Line which written in printer backside,three possibilities you said in that anotherone(square).
Hope this information help you. Have a great day.
May 26, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hwo I send fax from Ricoh2035
first plage telephone line in line and pluge telephone cable in beside socket in behind machine and press in fax option and put paper on feder and put your fax number in and press copy
Mar 26, 2011 | Ricoh Aficio 2035 Copier
How do I hook up an HP v40 to my PC and a cable modem so that my FAX works?
You probably need to hook up to a landline telephone line, too. Or, you can use an "e-fax" service that lets you send faxes via internet. Basically, they would send your fax as middleman to the recipient. Windows Vista except Business version) does not have inherent fax support like Windows XP and Windows 7 Professional. And programs such as WinFax did not upgrade to Vista and 7. But, your fax modem should have come with some faxing software.
You put in modem card and then run telephone line to back. You can usually run a line to a telephone from the 2nd connection on the back with the telephone symbol below it.
Hope this helps you a litle.
Nov 20, 2010 | Computers & Internet
Two telephone mastersockets?
First things first.
You want to drag the phone line around for the Sky+ HD connection?
Unless you use Sky Box office or other Sky online services you don't need to hook a telephone cable up to ANY Sky set top boxes.
The telephone cable is a means for Sky to monitor your box position and monitor your viewing choices.
If however you do use Sky's online services you "can" connect another line to you main line. Just make sure you connect the correct coloured cables to the correct pins in your sockets.
Further note...
For a Sky+ connection you need to coaxial cables coming off your satelite dish. Incase you didn't already know this.
Jul 15, 2010 | Lands Phones
How do I connect the fax to my home phone line. MFC 240C all in one printer
On the left side of the printer there are two telephone line connections, one is for the telephone line and the other is for the telephone extension. You will need two telephone lines, the type that have that clicker on the end, the line hole goes directly into the wall jack for the telephone and the extension line goes directly into the telephone that you had plugged into the wall. Try that, it works.
Feb 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Line 5 doesn't ring on one phone
That is done thru config programming, you need to add line 5, appearance and ring to station. This will automatically put the line on your next line button.
f** config
Aug 06, 2009 | NorStar M7324 Telephone
NO SETUP INSTRUCTIONS SUPPLIED WITH MACHINE. PLEASE SUPPLY
1. well its quite simple. all you to do is to connect the USB cable to the computer from the Printer (the printer also has a port for the USB)
2. then connect the main telephone line into the port labelled "LINE" behind the printer.
3. then you connect one end of the extra telephone cable supplied to the port labelled "EXT" behind the printer and the other end to the regular port on the telephone.
4. plug - in the power cable and put on the printer.
5. then you put the CD into the computer and run the set-up from the CD which is fairly easy.
6. after a few minutes you should have your printer running.
Nov 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
Dell OptiPlex GX110 PC Desktop Logo
Alun Cox
