Question about Lucent AT&T Speakerphone 825 (21211)
Programming numbers I have an old AT&T Speakerphone 825 and need to know how to program telephone numbers. It can hold 32 numbers but I can't remember how to do it and I can't find the manual anywhere.
  • Anonymous Mar 31, 2014
    How do I program numbers into my Lucent Speakerphone 925?
Press the button at the bottom left corner in the one touch dial section.  Dial the number you wish to program.  Press the memory button which you'd like the number stored under.  Repeat as needed.
Posted on Nov 27, 2008
YOU HAVE TO LIFT THE RECEIVER FIRST then press the button at the bottom left corner in the one touch dial section. Dial number you wish to program. Press the memory button which you'd like the number stored under. Repeat as needed.
Posted on Nov 19, 2009
  • David Oct 27, 2011
    You should've gotten more credit for that one added detail which is to lift the receiver first. I used the speaker phone button, personally. Thanks for the help!
  • gwstan Apr 23, 2014
    Thank you, and you are welcome, glad it helped you.
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
Need a manual or instructions for Durabrand 13 Memory-Speakerphone PH-3235
Try this site or look for Lenoxx PH-3235 instead of Durabrand http://www.retrevo.com/support/Lenoxx-PH-3235-Telephones-manual/id/22975ci268/t/2/
Aug 05, 2012 | Televison & Video
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still...
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Aug 30, 2011 | Panasonic KX-T7730 Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I need to know if the vodavi 30 button part number 3015-71 needs a lifter for a headset or not
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
Dec 23, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
I have a Norstar Meridian with M7310 phones. When calling out using the speakerphone, the microphone doesn't work. When trying to switch to hands-free during a call, it puts the line on hold.
sounds like your telephones not programmed for handsfree.
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Sep 14, 2009 | NorStar Meridian M7310 Phone
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Vodavi
Headset mode requires a button. In addition, the speakerphone needs to be disabled in admin programming.
Nov 03, 2008 | Vodavi 30-Button XTS Telephone
Binaton big button combo telephone
Press Speakerphone button
Press Set/Store
Enter the telephone number
Press Set/Store
Enter the memory number (M1, M2, M3 or 1-9)
Press Speakerphone button to hang up.
To use the memory feature,
For M1, M2 or M3, just pick up the phone and hit that button.
For memory number's 1-9, pick up the phone, press auto button, then enter number 1-9 for who you want to call.
Apr 16, 2008 | Lands Phones
Lucent AT&T Speakerphone 825 (21211) Logo
779 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
