Question about Lexmark X5470 All-In-One InkJet Printer
My fax part of my system not working
My fax part of my system ahas not worked since faxing some fine paper time sheets to my husbands boss cant send faxe since system is still under warrenty
No it says it is scanning page but it's not picking up the paper and putting it through it just makes the noise as if it is picking up the paper
Then it asks for a second pafe and does the same thing .
Basically its not picking up the paper th scan and send through I need it fixed before my warrenty ends
It pissing me off because at the moment I have to pay $2 per page to be faxed through the newsagent or the postoffice when I could be oing at home for nothing
Posted on Aug 30, 2008
    Problem Solver:
  • 19 Answers
Does it give you an error?
Posted on Aug 29, 2008
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
When i receive a fax everything is perfect,when i send a fax it reaches the destination where im sending it as a blank sheet of paper
If you are able to receive fax and it is printed out fine, there is nothing wrong with your printer. If the other person is receiving blank fax, you may be placing the documents to fax in opposite way, If you are placing the paper upside ( with text ), try to face it down and fax. It should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | Lexmark X6170 All-In-One InkJet Printer
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Receiving error
Ok...so I fixed my own problem. I had printed out a system data sheet on my fax machine and found out that the "error" was in under sending confirn, so I went into my menu to the sending confirm section and turned it off. Then my boss tried sending the fax and it came through like nothing was ever wrong...I think the other day when my Iguana got in my office, he must have done something, as I found him perched on my fax machine....hmmmm. Thanks for the follow-up email.
Apr 09, 2008 | HP 1040 Plain Paper Inkjet Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Lexmark X5470 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
