Question about Philips GOGEAR SA6045 MP3 Player
Need help phillips sa6045 mp3
I have phillips 4g mp3 sa6045........i also have an asus 4g surf4 laptop. The mp3 came with a 4in floppy with directions on it. my surf4 only has a small card reader, no place for a 4 in floppy?......it would be great if i could loadwhats on that 4 in right off the internet....
  • Anonymous Dec 04, 2008
    My mp3 says it has a file system error
  • Anonymous Jan 24, 2009
    mine wont turn off it just automatically goes to a white screen that says file system error
Your MP3 player, like any other storage device can be formatted. Plug it into your computer using it's USB connectivity cable and your computer will register the device as an external drive, assign it a drive letter which will appear in Windows Explorer. From there you can RIGHT click on the drive letter and select the option to FORMAT the drive. Once this is completed, you will probably be able to copy songs back onto the player. Right now I am trying to find a download that will allow me to load the firmware back onto the device so I can use all the features.
Posted on Jan 23, 2009
My mp3 want turn on i don't know if the batteries included or dead all I know that it stop working in I am trying to get it working again I done had it with this MP3 Player I am about to break it if it don't turn on
Posted on Dec 06, 2008
  • 8,596 Answers
Www.usasupport.philips.com
Posted on Aug 26, 2008
Where can I get assembly instructions?
Office Depot has the assembly instructions on their site. The direct link is http://www.officedepot.com/pdf/assemblyinstructions/846114.pdf .
I hope this helps.
(You'll need Adobe Reader or a similar program to read or print the document.)
Apr 16, 2016 | Realspace Zillope II Computer Desk, 56...
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Need p5vd2-mx se video and sound drivers
Drivers for windows XP
http://support.asus.com/download/download.aspx
Video Drivers - VIA 4in 1
Audio - Beta Version V5.10.0.5288
No need to install hotfix - it is for 64bit windows
Nov 18, 2010 | ASUS P5VD2-MX SE Motherboard
Need remote code for Phillips
tescos have the phone numbers for tech help desks at phillips and may have some codes
Mar 26, 2009 | Universal Remote Control Remote Control
Needs help to recover crashed asus r2h bios
You need to put the battery back in, try to find an IDE floppy drive to use and if the new bios version hangs then download the old BIOS and reinstall that -a computer that hangs is not a successful install or the upgrade is wrong. Pulling the battery doesn't revert to the old BIOS, just default settings for the BIOS installed. Using a USB floppy for this is not a good idea as the usb drivers must load -might as well use a thumb drive if this is a laptop. For a desktop stick with the basic IDE floppy drive. Best of luck, Steve Medley
Nov 07, 2008 | Computers & Internet
Maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Oct 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
How do u put videos on it??
download wmv to smv convertor aviliable on any of the web sights (search from goole)convert your videos and put in it its simple.
Jan 09, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
