Question about Miele CVA4070 Coffee Maker
Miele CVA 4070 coffee system
The coffee maker shows "cleaning" but will not finish the process I have tried powering off, unplugging the unit, but still get the same - cleaning
  • 3 more comments
  • maureenbyrne Oct 06, 2008
    I have the same problem! I remeber this happening way back when we bought it and the Miele repair man came out and gave me the reset key sequence, but I cannot remember it.... any one have it?
  • lillianemose Dec 05, 2008
    I have the Coffee System CVA4070 accidentally pushed "cleaning" and is now requesting that I place a tablet into the funnel. Where do I buy these tablets in Toronto? Is there a way to clear the screen or just cancel this command?
  • Anonymous Mar 30, 2014
    Need specifications
    need specifications
    need specifications
  • 231 Answers
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Posted on Jan 03, 2009
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
My miele coffee maker CVA 4070 how do I reset when it's locked in descaling
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
How do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Apr 12, 2009 | Miele Coffee Makers & Espresso Machines
I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback. Thank you.
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
752 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
