Question about Magellan eXplorist 200 GPS Receiver
Zoom in button works, but won't zoom out
As described...i zoomed in ok, but then it would not zoom out. is this something i can repair myself?
  • jalawson1 Oct 19, 2008
    Mine does the same thing. Help!!
  • jimmooney Feb 02, 2009
    After initializing, the unit will zoom in but not back out. Then, when changing to another screen, it will not go back to map page. ESC key intermittent, tried factory reset, which does not resolve the problem. Tried new batteries and clearing memory. No joy. Unit is effectively trashed. Unit has not been in extreme temps or moisture.
I had the same problem. took unit apart and used a white rubber eraser on the button contacts and also on the rubber back of the button. Cleaning the rubber back of the button seemed to be the most important part because prior cleaning of just circuit board did not seem to have any effect. Button works fine now to my surprise. I suggest cleaning the rubber back of all buttons to avoid repeating process of having to take unit apart twice
Posted on Dec 11, 2010
80-400 NIkon won't zoom on NIkon D700
Not if your other lenses work ok. I would contact the Nikon Repair Depot that cleaned it.
Jun 20, 2012 | Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR...
Dropped my JVC Everio and
Sorry to say you have to take the camera to a professional repair man, I've attempted to repair these myself but they are a pain to put back together.
Jun 15, 2008 | JVC Cameras
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
I just bought a canon Gl2 camera used on Ebay. I did the routine check, and everything seemed cool. I messed around with the zoom, and noticed that when I zoom in, at about 50 percent, it gets really...
This happens when the internal focus lens is off track, usually caused by impact and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 14, 2010 | Canon GL2 Mini DV Digital Camcorder
HF10 zoom goes without any explicit request
My HF10 started to mysteriously autozoom as well, and I had made no setup changes. I don't have exactly the same symptoms as you describe except that it would begin to zoom when I didn't want it to. I noticed the [I.AF] (Instant AutoFocus) icon, so I went into the menu (Camera Setup - AF Mode) and turned the "Instant AF" to "Normal AF". After that, the autozoom seemed to have stopped. I set it back to "Instant AF" and it did not autozoom again. I wouldn't know how to turn the autozoom back on again even if I wanted to, but thankfully it appears to be gone now. Hopefully it will stay in manual zoom mode. Hope that helps.
Dec 22, 2009 | Canon VIXIA HF10 HDV Camcorder
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
 Thanks for using fixya.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Casio ex-z750. I have a problem with the zoom on this camera. You can zoom in, but when zooming out it activates the 'Best Shot' scene selection. If you press the zoom button again the scene selection...
Sorry Chris but that is definately an electrical issue that needs to be checked by repairs. I recommend that you send that in so they can check the internal board.
Sep 13, 2008 | Casio Cameras
Card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
Zoom not working
if it´s under warranty, just send it to a repair centre they will fix it for free. anyway the lens will need to be replaced.
Apr 10, 2007 | Olympus SP-500 UZ Digital Camera
The SMART ZOOM is not working - doesnt either come up in SET UP menu?
I fixed my problem myself. Simply read the top of the camera1.gif where it says TO USE SMART ZOOM SET IMAGE SIZE TO LESS THAN 2.8M
Then go to the very bottom button on your camera (there are three) and press it and reset your image size.Then your zoom will work.
Problem solved.
Jan 11, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Magellan eXplorist 200 GPS Receiver Logo
176 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
