Question about Toshiba 57H82 57" Rear Projection Television
My 57 inch Probjection Toshibi had the best picture. The problem with it now is tearing in the picture and wavy horizontal vertical lines. Problem is most prominent with DVDs. Initially the picture is unusable but eventually clears after about ten minutes. Also, problem is present on digital and high def channels.
  • angela32751 Sep 09, 2008
    I have the same destorted picture for the first 5-10 minutes when the tv is turned on for the first time... The sound also takes a while to warm up and work. Now it takes about 10-20 minutes.. unfortunately I have no money to have it fixed and was hoping someone can help me do it myself. Unfortunately the economy is tight and so is my pockets. I would really appreciate the help. More than you'll ever know. This happened before and it was under warranty. I show the description for the fix was replaced hyper module, convergence, test unit. Hope this helps you.. I just need to know if I can actually change one on my own and HOW??
The hyper module is located in the metal box just behind the panel where all your cables plug into the tv. It is sodered to the board syou have to get under neath and melt the four places that the metal box is sodered. Once it's out you can either replace the whole board if you can find one. I can't seem to find it anywhere. you can also chage out all the 16v 10uf capacitors which is generally the source of the problem, but even these seem to be very difficult to locate now too.
Toshiba doesn't carry them anymore. Here is a link to the bulletin they put out becuase those capacitors are a known problem and failure point.
http://www.nesda-ohio.com/member/toshiba/PJTV200503%20Technical%20Bulletin.pdf
If you locate the board for replacement on the net please post a reply to this thread i'm in search of. Thx.
Posted on Mar 08, 2009
  • Toshiba Master
  • 8,617 Answers
Hyper module is going out, common problem with Toshiba rear projection TVs
Posted on Aug 25, 2008
24af45 from top to bottom picture is wavy until set warms up
Check and replace all the electrolytic capacitors at its vertical scan output stage circuit. Replace all of the once.
Apr 04, 2013 | Toshiba 24AF45 24" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Panasoic PT-47WX49E
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Toshiba 57H82 57" Rear Projection Television Logo
555 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
