Question about Sharp Office Equipment & Supplies
Sharp photocopier arm205 toner dust on about the first 10 pages when machine is cold.-Then it clears up.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Soething wrong with
1-drum blade
2-"waste toner" cleaning mechanism
I would replace the drum blade, empty the waste toner and check to make sure it is operating ok.
Posted on Aug 25, 2008
How do I check the number of copies the photocopying machine has made (Sharp 5620). Thanks
Download User manual, page 121, CHECKING THE TOTAL OUTPUT COUNT AND TONER LEVEL.
Hold down zero Key and display will tell you 3 + 3 numbers of counter. (audit mode is off)
Sep 03, 2016 | Sharp Office Equipment & Supplies
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
Toner, Drum and Developer
it depends the how the machine was set but normally you can copy up to 50,000 pages
Jun 19, 2014 | Sharp AR-5320 Black and White Copier
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
ARM205 Error Code CH. what is wrong with our Sharp Copier
If CH flashing reinstall your toner cartridge properly if not that mean you have an open door close it.
Dec 29, 2010 | Sharp AR-M205 Copier
Is the Sharp arm205 networkable?
It requires an optional AR-NB2N network box that fits on the back of the machine and plugs into the USB of the copier. It will be obvious and clearly labeled if it is there.
Oct 21, 2010 | Sharp AR-M205 Copier
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
SHarp Z-20 home photocopier toner refill- Manual?.
There is a small door at the right front, unlatch from the top, open the door and unlatch the green tab on the cartridge and pull the cartridge out.
Mar 17, 2009 | Sharp Office Equipment & Supplies
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
Red man flashing on photocopier
Hi Your Copier needs a service, that is what that led is for Hope this helps Regards
Aug 08, 2007 | Sharp AL 1215 Black and White Copier
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
