Question about Honeywell Heating & Cooling
Cannot move the temperature lower - Honeywell Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
The lowest setting? Lower than what ?t
Posted on Aug 25, 2008
Lazy-spa hot tub saysE03 what to do
E.0.3. The pump’s thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F). 1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
Dec 28, 2016 | Pool & Spa
Why does my fan always run intermittently? During traffic jams my fan will run about 25 times intermittently, and I check my temperature it is still normal?
sounds like problem with the temperature sensor or relay that controls the fan(if electric) check the sensor and relay one may need to be replaced.
Mar 24, 2015 | Cars & Trucks
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
We purchased a 2013 camper with a dometic refrigerator and today the temperature is up to 48 degrees
move temp sensor in fridge lower or let hang if ok tomorrow replace if not bad sensor
Sep 22, 2012 | Dometic Refrigerators
We need to set water temp but can't find where to do it on the heater
The Atwood temperature adjustment is on the gas valve.
There is a metal lever sticking out.
http://waterheatertimer.org/gas-water-heater-timer.html#Atwood
Move the lever one direction, and if burner turns on, then move lever other direction to lower temperature.
If your gas valve is different, you might find answer on following page:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have the Reliance 606 and my water has been extremely hot - do I need to change both of the heating elements in it
Are you aware of how to adjust thermostat(s) on water heater? Be sure to shut off power (circuit breaker(s) to water heater prior. Should be behind covers on tank. Both should have screw in center to allow you to back down temperature. Should have an arrow indicating current temperature setting, simply move it slightly toward lower temperature (usually counterclockwise, but just double check ) and try it, until desired temperature is reached.
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
Wear is the heater valve located in a 95 cadillac deville
Hello, There is not a heater valve, the temperature of the heater output is controlled by directing the air flow either through or around the heater core or somewhere in between depending on what temperature you want. There are actuators on the passenger side attached to the programmer. Remove the glove box and lower closeout panel on the passenger side with key on change temp setting and they should move, the lower one is for the driver side. These actuators were a high failure item.
Oct 01, 2010 | 1995 Cadillac DeVille
Heater blows warm air
First thing, check coolant level. MAKE SURE THAT COOLING SYSTEM IS COLD BEFORE REMOVING RADIATOR CAP!!! If the coolant is full, then you need to go inside and check under the dash[you may need to remove lower hush panels] find the control cable and crank arm for the temperature control. Move the temperature control lever on the dash control to confirm and make sure the arm moves.
Nov 01, 2009 | 1998 Chevrolet Blazer
Heating & Cooling Logo
29 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
