Question about Kenwood DV-6050 Multi-disc DVD Player
APEX AD-1115 DVD PLAYER
WHEN DISC IS INSERTED, I GET A MESSAGE THAT SAYS "BAD DISC"
I TRIED INSERTING A LENSE CLEANING DISC BUT I GET THE SAME MESSAGE AND THE DVD PLAYER DOESN'T PLAY THE DISC
  • soup127
    soup127 Dec 23, 2012
    Loreto Lacaron - you totally fixed my Cyberhome 300 DVD Player... I greased the slider rail and cleaned the lens, and wallah! All better. But I still have this Zenith DVB312 that plays DVDs super choppy and then slows down just stops every now and then. I tried the lens cleaning and the rail greasing, but no luck yet. I'll try some of the other stuff you mention, but I'm curious if you can diagnose it from the description I gave.
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
Manual
Eventually you will purchase a replacement remote or maybe a universal remote that will operate your Apex player
Jun 30, 2013 | Apex Digital AD 1115
Why is my apex dvd player showing movies in black and white
check the connections, a lose cable will cause colour loss.
Mar 04, 2011 | Apex Digital AD 1115
Apex dvd player door will not open
Can you hear any noises from the drive when you press the Eject button? if no then the motor is faulty but if you hear noises but it still doesnt open then the belt could be slipping or broken.
Nov 04, 2009 | Apex Digital AD 1115
Disc inserted upside down now dvd player won't
Ur disk is not readable to the laser eye.
That why u can't open the disk tray.
Must take it aparts to take out the disk.
U just hope the laser eye not damage.
Aug 17, 2009 | Apex Digital AD-1100 DVD Player
My apex & aiwa
everest,
Give cleaning the lens a shot, or blowing some air inside the tray.
Aug 23, 2007 | Apex Digital AD-1110W DVD Player
Dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
Jul 09, 2007 | Apex Digital AD-1110W DVD Player
Kenwood DV-6050 Multi-disc DVD Player Logo
435 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
