Question about Hunter (25417) Ceiling Fan
Hunter Fan the light works fine, when you use the remote for the fan, you hear a click but it does not turn on.
  • john886 Mar 11, 2009
    I've owned the fan for a couple of years and had no problems. However, now when I use the remote to turn the fan on I hear a click, but the fan does not run. The light works from the remote.
  • lakenjade Apr 21, 2009
    Light works from the remote, but I only hear a click when I push the button for the fan. The fan will work occasionally but you never know when!
  • 89 Answers
Check your remote sensor inside the fan housing and make sure it's wired properly. Sounds like the solonoid is not wired correctly to the light. Hope this helps. Good luck.
Posted on Aug 25, 2008
  • Charles ogden Aug 25, 2008
    Sorry, not wired correctly to the fan.
How do I repair a Hunter Ceiling Fan thats blades won't spin?
The remote receiver could have failed partially so only light control works.
May 26, 2015 | Hunter Dryers
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
May 30, 2014 | Hunter Ceiling Fan Light Remote Control
My Hunter Fan stoped working. The light works but the fan does not work on any speeds. I hear the fan click when I press the different speeds on the controller. My grandaughter was here and kept taking...
If you hear any humming from the fan when you're trying to turn it on, then your motor is froze. I'm thinking from your description of being able to hear the actual fan switching but getting no results, it's probably the motor.
Aug 28, 2017 | Hunter Ceiling Fan Remote Receiver...
Remote does not work at all - light comes on (with the switch) and the fan did work fine but then slowly the remote did not work - there is no chain and yes I replaced the remote battery twice- now it...
if hunter remote does not turn on fan. then problem with remote or the fan receiver. remote part # 85095-1. just type hunterfan.com in browser, and click support to find phone number for help. have a good day !!
Dec 14, 2010 | Hunter (25417) Ceiling Fan
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Jul 12, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hunter (25417) Ceiling Fan Logo
289 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
