Question about Dishwashers
Dishwasher/garbage disposal problem
After installing a new garbage disposal, my dishwasher now sprays water all over the counter as it drains. The water sprays from the air valve that sits on the back of the sink. It has 2 hoses connected to it. They are size specific so I don't think I have mixed them up. Do yoiu know what I did wrong? Thanks!
You probably forgot to knock out the plug in the disposer for the dishwasher.
Posted on Nov 07, 2008
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Water wont drain
If the water in your dishwasher does not spray or drain properly, there are a number of things you can do. Start by giving your dishwasher a thorough cleaning and see if that helps. See How to clean a dishwasher for step-by-step instructions.
Next, consult the owner's manual for simple instructions on how to access and clean your dishwasher's filter.
Look where the dishwasher drain hose snakes through from one cabinet to the other. Does the hose look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process. You may need an entirely new timer or a new motor for the timer. Repair service is recommended.
If you hear a humming or grinding noise, that's an indication that bits of glass, broken dish pieces, beans or seeds may be caught in the pump impeller.
For more troubleshooting steps and solutions, see Dishwasher not draining. I hope this helps!
Sep 20, 2012 | Kenmore Dishwashers
Water will not drain. I did have a new garbage disposer installed a couple of days ago, but don't know enough about dishwashers to even see where it connects to the disposer.
Hi Ruthp53, I am JK. I see that you have installed a new garbage disposal and now are having problems with your dishwasher (model FGHD2433KF) draining. I would recommend checking for blockage at garbage disposal and the drain. Also, new garbage disposables normally have a plug that will need to be taken out.
Hope this helps!
Sep 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My new dishwasher leaks water on the floor about an hour after it is completely finished with the cycle
Make sure the drain hose connected to your garbage disposal is connected well. Also, the hose should loop up near the sink (counter top) before it loops back down about 3 inches below the drain connection on the garbage disposal (or sink drain pipe if you don't have a disposal). This effectively makes a drain trap to avoid any smell from the dishwasher.
Also make sure the door is closed properly and there is no packaging material on the door.
Jul 16, 2011 | Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The part by the sink causes water to flow all over the counter
Almost all dishwashers connect to the sink drain in one way or another. Many connect (via an Air Gap valve) to a garbage disposal.
If the "metal part" is at the rear of the sink, that is the top of the air gap. When water comes out of it, that means the drain is plugged.
If there is a garbage disposal, does water drain through it? Does the disposal work?
If there is no disposal, does water from the faucet run through the drain of each sink with no problem?
Thanks for answering these questions in a reply.
Apr 10, 2009 | GE Dishwashers
Water not draining whirlpool quiet partner ii
Remove the drain line where it hooks into the disposal. See if the plug, which must be removed to let water thru, is still in there. I ran into this on a service call a few years back. Removed to plug and voila! Hope this helps!
Jan 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
Jan 12, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Bad smell
It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
May 18, 2007 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
254 people viewed this question
Top Dishwashers Experts
