Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Blank screen Screen goes blank just after Windows XP is ready to open, just before the opening theme music. Screen reads "recommand mode" after the blank and then goes blank again. In safe mode, it is working but I cannot find anything in Windows to fix it. Screen also works fine for my laptop.
  • 89 Answers
Try to reinstall the drivers of your video card while you are in safe mode.
Posted on Aug 25, 2008
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I am open windows till the windows xp screen will open then next it will blank what will i do?
try booting to safe mode
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 27, 2011 | Computers & Internet
Screen flickers so that screen is unreadable. I can connect to an external monitor but once you get past the windows xp startup screen the external monitor goes blank and the laptop monitor lights up but...
try uninstalling the graphics driver and reinstall, also boot up in safe mode and see if you can see screen ok, if you can its your graphics card as in safe mode no agp drivers are engaged
Feb 14, 2011 | Computers & Internet
My windows is not starting up
Dear i have send some information of your problem.
i hope you can read it and solve your windows problem.
Thanks. Aman.
ok my situations is
when i turn my pc it goes thru the normal procedure of starting up. all the way till you see the windows xp logo then it just goes away and the monitor is blank (a black screen). i tried the repair and that did not fix the problem. when i try to go open thru safe mode it tells me that windows xp setup cannot run under safemode. setup will restart now. can you help please i don't want to loose all my information on my hard drive so i really do not want to reformat and start all over. thanks
Feb 16, 2010 | Computers & Internet
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
How to fix windows xp look that shoud egzist in my sys. anymore,it only can wiew in classic windows mode
You want XP to look like when you first got it and not in classic mode, am I correct? If that is the case, do the following:
  • Right click on your desktop and select Properties
  • Go to Themes tab and select Windows XP and press Enter
That should bring you back your screen. If that did not help, then do the following:
  • Right click on my computer and select Properties
  • Click the Advanced tab
  • Select Visual Effects tab
  • Chose either Adjust for best appearance or you can let Windows decide what's best for your system.
Finally, if that does not work go into Control Panel --> select Administrative Tools --> Services. Look for Themes in Services to make sure that is is both set to Automatic and that the services is started.
Mar 20, 2009 | Microsoft Computers & Internet
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
My computer will not reboot
this will either relate to a hard disk fault or a corrupt driver or registry file, if you cannot get into safe mode, or last known good configuration, you may have to run a windows repair using your XP cd
Sep 14, 2008 | Microsoft Windows Vista Ultimate Edition
Computer won't open DJ Ditty
Windows Media Player 11 not compatible with this player.
The device doesn't know if it is a MTP or MSC device - in one of these modes, it will not allow access to the music folder. unfortunately, there is no way to switch between these two modes in the menu settings. Go to Control Panel - Device Manager - find MTP Deivce and update driver.
Sep 28, 2007 | Dell DJ Ditty MP3 Player
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
493 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
