Question about Acer TravelMate C112TCi-SP2 Tablet PC
Acer Travelmate C112TCi- Won't power on
My computer was working fine last night. I left it on the AC power to charge the battery overnight and it won't turn on at all today. I tried plugging it in & unlugging the AC power and nothing... Help!
  • Anonymous Mar 24, 2014
    have charged and will not turn on. last reading was low battery.
    Master:
  • 636 Answers
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Posted on Oct 03, 2011
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
Why will my battery not charge?
I will assume you are finding the procedure to remove battery for the ACER travelmate C300 tablet PC. Best way would be to go to page 50 in the service manual available at this site.
http://tim.id.au/laptops/acer/travelmate%20c300.pdf
The battery not charging could simply be the battery is old and dead or the charging circuit is faulty. Start with the adapter in that case as it is cheapest to replace.
If you are removing parts to diagnose further then I would strongly suggest you video what you are doing in order to get back to where you started.
Sep 26, 2014 | Acer TravelMate C300 14.1 XGA LCD Display...
Ipad won't turn on. Worked fine last night, got down to about 5% battery left. Plugged in overnight and it won't turn on. Tried different power cables, no success. Tried plugging into PC no luck. ...
You could try a hard reset.
Hold down the power button and the home button at the same time until the device completely shuts down and the Apple logo appears.
Hope that helps!
Sep 24, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My google nexus 7 wont turn on
Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
NOTE:
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
Please post update/feedback asap. Thanks
Oct 10, 2017 | ASUS Google Nexus 7 Tablet
My Digix Tab-720 is stuck on Android screen
I had the same thing happen to my Digix Tab 720 last night. This happened after I reset the tablet to factory settings. I left it charging over night and this morning, it is working perfectly. Hope this helps.
Aug 13, 2012 | Tablets & eReaders
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Why my acer travel mate c110 cannot touch screen ??? is it got a software to install it ? i go acer dun see any software for the Change tablet and pen settings. pls help me ~~~~~~~~~~~~~~~~
Try installing the drivers from the Acer website. The link is
http://support.acer.com/drivers_download.aspx
Select Notebook>TravelMate>TravelMate C110
Under the drivers tab, you will find all the drivers you need for your laptop. Don't forget to select the Operating system or else the drivers will not show up.
May 31, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer Travelmate 2200 laptop
Try taking the laptop battery out. You can remove the laptop battery by turning it over, you'll usually see some sliders at the bottom, slide them to the unlock position and you should be able to wedge your battery out. The battery usually comes in a very tall and thin rectangular shape. Once the battery is out, plug the laptop in through the mains power - this may solve your problem, if it does, you'll need a new battery if you wish to use it on the move. If it does not solve your problem, it is either a faulty power adaptor, or a faulty power supply on the motherboard of your laptop. A faulty power adaptor or battery is the best case scenario, as it's the cheapest to buy a replacement (although it's still expensive - $120 worth in the UK roughly). A faulty power supply on the mainboard generally means you'll need a replacement mainboard which is totally uneconomical, especially with the labour cost to fit it professionally. If the battery and power adaptor is not faulty, you might as well scrap it and get a new laptop. Good luck Tina!
Sep 07, 2007 | Acer TravelMate 302XCi Tablet PC
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer TravelMate C112TCi-SP2 Tablet PC Logo
278 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
