Question about Maytag MER6772 Gemini Electric Kitchen Range
Door safe luck
I have maytag double oven mer6770 we have problem with doors luck
self clean we can't open the door ,we unplug the powers no changes
please help me to open the both door
thank you
  • nahila Aug 25, 2008
    i turn power off for about one hour
    the door is lock
    please help
    thank you
  • 868 Answers
You will have to replace the door latch assembly.It is difficult to release the latch if it jambs closed.You have to have the experience to do this or you will just make matters worse.
Posted on Aug 25, 2008
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
Maytag range model mer6750 - I tried to open the oven door too soon after a self cleaning cycle Now door won't open and fault code F9-2 appeared. What to do? THANK YOU
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
F9 Door Lock Warning Check door lock circuit or Replace Clock
F-2 Oven temperature sensed by electronic control Replace the clock/relay board.
Here is the part you need to order.
May 18, 2013 | Kitchen Ranges
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Dec 22, 2008 | Maytag Kitchen Ranges
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
133 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
