Question about Maytag Neptune FAV6800AW Top Load Washer
Od code read your responce on the three cycle and followed your directions. Did not work for me looked at the maganet all looks good please help
    Novelist:
    Champion:
  • 261 Answers
This is your switch if you have a fav6800 series machine if different let me know, the switch also has a finger which attaches to the lid that often breaks. Look at where the lid meets the console right in the middle should be a 1 inch square of plastic whith a finger that presses a plunger to activate the switch, the plunger and switch should be intact together inline. Let me know of your findings.
Posted on Sep 11, 2008
Staying in od but if I shift manually to 2nd and shift up it does fine!
Sounds like a shift solenoid died. I would replace both of them. Have the codes read.
Dec 02, 2015 | Cars & Trucks
Od error code
The Neptune Od code will come up when the unit does not see the door opened before starting another cycle following a completed cycle. Simply opening the door and closing it again will remove this code until the same incidence happens again. So if you are looking to rewash a load of cloths you must first open the door then close it before you can start the machine over. Pleazer Appliance...
Apr 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
Subaru Impreza 2.0 Turbo hesitation/bucking
You say nothing about any fault code testing being done.
Jun 18, 2017 | Cars & Trucks
1990 Suburban 1500 with diesel and 700R4....Driving on freeway at normal speed in overdrive.... suddenly vehicle downshifts out of OD, and blows fuse for dash gages. When fuse replaced, and with ignition...
To begin with you are OBD 1, dont relie for a code its limited, there is a short touching ground, well first lets do the operation and work are way in 700r4 is a 4l60 so 1990 makes it a 4 or 3 wire connection so lets start here, (because it will make a trouble shooting tree sense) three terminal then trouble shoot it . on the transmission 1.Ignition(+) ,2. fourth clutch control 3. TCC control. . Here its three wire leading to transmission . The most problable is the ignition wire, that goes to the transmission when this goes it peg the speedometer, and because its ignition or IGN(+) we will be concern about this on,because without it it wont let you move the gear so lets follow its route and see where it will touch. something is interrupting this circuit. from ignition switch it goes to brake switch so look at the brake switch open the harness wire if you have to.and look for wire touching, then it goes to transmission Okay I am stump here also so OD is shorting (IGN+) Do this better it a all in one shot get the harness at the transmission its a three wire four pin connector inspect that connector open the harness if you have to , look for zip ties that may have squeezed open the wire together,trouble shoot the IGN wire from steering to OD switch ,you may have to replace the IGNition wire from brake switch to key area to transmission
Apr 29, 2011 | 1990 GMC Suburban
I get OD code
od meaning from the Service Manual for the FAV6800A/FAV9800A;
Open the Lid: The lid has not been opened for the last three completed cycles.
The OD and OP error codes are trouble shot the same way. See if this link will help.
Left Hand Lid Lock Troubleshooting
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........D*ick
D*ick
Aug 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a letter showing and it say O D WHAT IS THIS MEAN
od error code description from the Service Manual for the FAV6800A/FAV9800A; Open the Lid: The lid has not been opened for the last three completed cycles.
If only it were that easy to fix.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
See page 13 of the Service Manual for a list of the error codes and their meaning.
I feel you have lost Lid Open/Lid Closed signaling to the Control Board from the Left Hand Lid Lock assembly. If you remove the Left Hand lid lock assembly I believe you will find a broken wire to the magnetic read relay or severe corrosion on the input and output pins in the Left Hand Lid Lock assembly.
Take a look at this link Left Hand Lid Lock Troubleshooting and see if it will help with troubleshooting and repair.
You will find a part number for the Left Hand lid lock and parts supply vendor links if you decide to purchase the Left Hand Lid lock.
I would do some troubleshooting by removing the Left Hand Lid lock and inspecting before a part purchase………Rich
Mar 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
"od" alarm on neptune tl
Hey geonkarla637,
Good job on troubleshooting, let’s focus on the Left Hand Lid Lock. It has the dual signaling functions to allow the Machine to operate as designed. The first signaling function is “Lid is Open/Lid Closed” signaling the “OP” error code for lid is OPEN if you press the Start button at the Start of a cycle or during a pause and resume portion of a cycle and “OD” error code if the machine has not seen the lid open for three completed machine cycles your issue. The second signaling function is “Failed to Lock” the “FL” error code.
Because the Control Board programming is looking for the contact open/closure transitions at appropriate times of the wash cycle from the Magnetic Reed Relay in the left lid lock. I see no way to fool it by bypassing the magnetic reed relay in the Left Hand Lid lock assembly and have the machine work as designed.
What I would do next is remove the Left Lid Lock and very carefully open it up. I found it is very easy to break off the enclosure locking tabs. I use a fine flat jewelers screw driver and X-acto blade and work around the locking tabs to open the case halves. I wedge small paper clip ends in the case halves as I work around the tabs. Again I stress they break off in a heartbeat take it slow and no coffee for 24hrs before you begin this operation …. (:
How do the black and red wire on the reed relay look? If they look like this I would take a low wattage soldering iron fine pencile tip 25W no more than 60W iron and solder back on the broken end if that has happened. If you don’t want to deal with that you need to replace the Left Hand Lid Lock .
I would also use a drop or two of WD-40 on the slide switch in that signals “Lid Is Locked”. I’m going to include a pic of my attempt to document the Left Hand Lid Lock Control Board inputs and signaling outputs. I have labeled the Pins on that lock assembly for my reference, I cannot correlate them one for one to the schematic packed in the machine console. I have measured and watched the +12VDC input and output transitions with my DVM for the Lid Is Closed and Lid is Locked on the Control Board at connector P3. If your Left Hand Lid Lock is signaling correctly out of the assembly then I would trace the +12VDC signaling back to the control board. From your previous troubleshooting you have insured there is no corrosion on the male Left Hand Lid Lock assembly and the mating plug end.
Please let me know what you find, I hope this helps; I’m a rookie owner still learning how to troubleshoot/repair the machine.
As a side note I unplugged the Right Hand Lid Lock and taped up the plug end. I would never replace that lid lock if it failed my choice; I find it helps to simplify troubleshooting.
Good Luck …………..Rich
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The OD code will not clear
The Service Manual for reference. Sears Parts Direct for reference
od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock and or lid magnet issue.
First check to see if you can clear the od error with an external magnet as shown in this picture.
Pic of left bumper and a external magnet;
If it does then you have a lid magnet out of position. You will need go thru the process to disassemble the lid and check that the lid magnet is in position. First picture on page 35 of the SM shows the lid magnet.
You could have an issue with the left lid lock with corrosion and a possible open lead on the reed relay in the left lid lock. See the broken black wire connection as shown in this Pic
In the interim you could power down the machine by removing the 120VAC power cord from you wall receptacle then re-power up. That may give you three more wash cycles before the od alarm is triggered again. If the magnetic reed relay lead is open as shown this may cause a OP alarm to the console.
Post back if you have questions. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Celica 4WS, auto, 1990- overdrive not working
The fuse for the overdrive is the 15 amp "Gauge" fuse. Since the OD light is working, the OD system is getting the right power. Methinks that you have, at best, a seized or sticking OD solenoid. What I would do at this point is to take the old girl to a service facility, and treat her to a complete transmission flush. Not just changing the fluid, but a complete flush. This may clean the sticking plunger on the solenoid, and get you & her back on the road. At worst, you may need to change the OD solenoid. Not too awful expensive. Get her flushed, and post me back. Thanks.
Oct 08, 2008 | 1989 Toyota Celica Liftback
Three-digit code for prima tv for universal control
If you can't find it under prima look under legend
If not read your manual and depending on the remote you have a option for the remote to find the code by itself
Just have to follow the instuction in the remote user's guide in the place that says "Brand not listed"
Good Luck
-John-
Dec 29, 2007 | Televison & Video
Maytag Neptune FAV6800AW Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
