Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Not cooling or cold
Our whirlpool fridge is not cooling it has slowly been getting warmer and now it is barely putting any air out. The light and the fans are running but we have no cooling. The divider is warm between the freezer and the fridge. The freezer is at a low fridge temp now.
  • Anonymous Mar 13, 2014
    freezer is cold but the fridge is not. Does it have two evaps or does the freezer supply cool air to the fride by a damper or something?
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Posted on Sep 07, 2008
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
The temperature in the refrigerator side has slowly gotten warmer to where it's now at 50 with max
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 24, 2011 | Jenn-Air JCD2389G Side by Side...
Refrigerator not getting cold enough
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
386 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
