Question about Olympus D-630 Zoom Digital Camera
Settings are reset
All my settings are reset every time I turn the camera off, can I save them?
    Master:
  • 852 Answers
The camera can be set to retain all your camera settings each time the camera is turned off and on. Press the OK/MENU button. Then press the right arrow to access the Mode Menu. Press the down arrow to highlight the SETUP menu. Press the right arrow to highlight ALL RESET, and then press the right arrow again to highlight ON. Press the OK/MENU to save this setting and return to the Mode Menu. The camera will now retain any settings such as Quality each time you turn off the camera.
Posted on Sep 01, 2005
Settings Reset
DId you try reseting it by removing the battery and memory card?
Jun 13, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
I am unable to take pictures after turning on the camera. Each time I turn the power on I have to go through all the set up steps in order to take a photo. How can I go through the steps and save them so...
make sure that you don't have virus in your memory card. format all memory spaces and then again reset it. restore to factory setting
if you like this kindly rate me
Oct 12, 2010 | Casio Exilim EX-Z750 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
I have a sony cyber-shot dsc-w55 cammera, and my daughter turned the dial that changes the picture modes to many times and now it only records on every picture mode...any ideas how to reset it?
Based on the information you provided, it seems that the Camera is in Burst or Multi-Burst mode.
You may Initialize the Camera as follows:
Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Set the mode Dial on Camera. then, press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK.
Good Luck!!!!!!!!!!!
Nov 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D80 - Singe Focus Area
once you have your settings, is there an option in the menu to save your profile? ( I do not have a Nikon DSLR..) If you can, try saving your profile and then restart again.
"Auto" modes generally are designed to reset to the pre-defined automatic settings, so it may not be possible to keep your changes every time.
Also, you can update the firmware, however there is no mention of any changes which should affect this issue.
http://support.nikontech.com/app/answers/detail/a_id/16091
Aug 31, 2009 | Nikon D80 Digital Camera with 18-135mm...
Sony cyber-shot 7.2-Megapixel Digital Camera pink DSC-W120 lens keeps going in and out it want stay out so its says turn your camera off and on again I keep doing that but its doing the same thing every...
Option 1:
Try Initializing the Camera as follow; (Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
Aug 26, 2009 | Sony Cyber-shot Digital Camera
Dropped camera dsc-w120.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Press the Home button on the Camera. Then, select the SETTINGS -> MAIN SETTINGs -> MAIN SETTINGS 1 -> INITIALIZE -> OK.
Option 2:
Aug 20, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Selected resolution will not save
You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
Aug 21, 2008 | Olympus Camedia C-350 Digital Camera
Olympus D-630 Zoom Digital Camera Logo
63 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
