Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Aug 25, 2008
Sending fax Can I send a double sided fax?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
100
Points
0
MY BROTHER HAS A CANNON MP530 AND ALL OF A SUDDEN HE CAN'T SEND OR RECEIVE FAXES. I HAVE BEEN TRYING EVERYTHING THAT I KNOW TO DO AND CAN'T SOLVE THIS PROBLEM AND I USUALLY CAN. IF ANYONE CAN HELP ME HERE I WOULD TRUELY APPRECIATE IT. HE HAS MY ALL IN ON AND I AM TRYING TO GET HIS UP AND RUNNING AGAIN
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
5helpful
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
** Adjusting the Image Quality (Fax Resolution)
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334
Definition
Solutions
2" BOTH SIDES WHEN SENDING BLACK
This is because your **** Glass is Dirty Clean your **** Glass and it will be ok.
remove ALL WHITE OUT
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
3helpful
2answers
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
2answers
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
old marine
old marine
ZJ Limited
ZJ Limited
