Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
  • 8,596 Answers
Unplug for 20 minutes to fully reset, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
223 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
