Question about GE Dryers
Ge electric dryer ...dbxr453et5ww...when door is opened while in cycle drum stops but heating element does not.
  • 209 Answers
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
Posted on Sep 29, 2007
  • 3 Answers
SOURCE: how to get to heating element on ge dryer
Sorry but Ge dryer don't have back covers .... take out the top first ( 2 screws in the top of the door opening ) then the front and the drum ...voilà
Posted on Nov 30, 2007
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
  • 33 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer not heating up
Check the air flow from the vent-if there is no air or very weak air flow, it is the blower motor. It is not getting up to speed or not spinning at all. Try this:
Press "Home"
Press "Help"
Simultaneously press and hold down BOTH
"My Cycles" and "Back"
After a few seconds the dryer will enter service mode and report any problems.
Pertains to GE Profile HarmonyDPGT750EC/GC
Posted on Aug 07, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
How to check and replace dryer's heating element for GE 5.8 Cu. Ft. 3-Cycle Extra-Large Capacity electric Dryer -...
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Oct 01, 2011 | Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
Apr 20, 2010 | GE DVLR223 Dryers
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Dryers Logo
141 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
