Question about Linksys Wireless-G WRT54G Router
How to install linkys without the cd
How can you install linksys without the cd
    Sergeant:
    Champion:
  • 236 Answers
Just hook it up to your modem with an ethernet cable. turn it on.
either connect your computer to the linksys with another ethernet cable or via wireless. the default SSID (name of wireless network) is linksys with no password.
once connected, you can access the linksys settings page by typing 192.168.0.1 on the address bar.
there, you can put a password to your network, set who can connect to your network, and many other settings.
But it should work without the cd.
Posted on Aug 25, 2008
  • Linksys Master
  • 6,487 Answers
You can manually install it even without a CD, if you dont know how to do that you can contact Linksys tech support so they can walk you through in configuring it manually , this is the number 800-3267114....
Hope that helps..........
Download installation cd linksys wrt54gs
You could install the Linksys WRT54GS without any CD.
You could use the Linksys EasyLink Advisor to scan your network for the Linksys WRT54GS.
The Default IP-address is 192.168.1.1 so you should be able to connect to the Linksys with your Webbrowser when you do a factory reset of the Linksys.
Jan 26, 2014 | Trendware TEW-452BRP Wireless Router...
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I misplaced my linkys cd. Is there any other way I can install linkys onto my computer to make in wireless?
The best thing to do is install Tomato or DD-WRT firmware on your router. This will increase your router's potential ten-fold.
Lifehacker did an excellent write up on doing this. Go to: http://lifehacker.com/#!178132/hack-attack-turn-your-60-router-into-a-600-router
Hope that helps!!!
Feb 14, 2011 | Linksys Wireless-G WRT54G Router
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
1.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
2.
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
3.
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
4.
turn on modem, linksys then pc
5.
loging to windows - open IE on address bar type 192.168.1.1 - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
6.
Now try yahoo.com in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
I have linkys wireless router model wrt54g2v1.after i back up my computer i lost the linkys file. i cannot find cd for installation. now i am unable to open internet.
mpshyla
The reason for the CD is to configure the router to your cable modem. So if you reinstalled your computer you do not need the CD again. All you need to do is set the computer's Gateway back to your router. The links below will help you do this.
http://www.fixya.com/support/r4602477-check_change_computer_ip_address_in
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Linksys WRT54G2 Wireless Router
I reformatted my computer and i cant get drivers
If you have linksys hardware install the cd that came with hardware and get to linksys website and download latest driver. Reformatted cleans drive to zip data and you needed to reload XP to get it going so anything you installed after the system purchase you will have to reinstall.
Aug 29, 2009 | Microsoft Windows XP Home Edition
I had linkys at one time on my computer. I tried
just go to control panel> add or remove programs> and click on any programs connecting with the name linksys and then click remove to uninstall it.that will remove all the components for linksys from your computer including the one for the start bar.
Jun 06, 2009 | Linksys Cable/DSL 802.11n Security Rtr...
Installation is stuck at 30%
hi
may be the installation software is not working,what you need to do is take the cd out from the computer and just plugg the wireless adapter,when you plug in the wireless adapter it will tell you to insert the cd that came with the usb card so that the software can be installed,once you see this message insert the cd and then follow the setup screen(imp thing:incase you see the screen of the linkys installation donot follow that,follow the windows software setup screen) this will install the software and i am sure the software will get installed if the software has totally gone bad then here is a link you can donwnload the software from website and then try the installation
link for linksys wusb54gsc for :
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1154470123093&pagename=Linksys%2FCommon%2FVisitorWrapper
vedhick
Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys Wireless-G "Error: Hardware I.D. Missing"
Make a Product Registartoin at Linkys and you will get all the help you need, you can even get a new cd with driver for a smal amunt.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1166859677851&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7785163308L24
Coockies would be nice yes thank you! *lol*
Good luck M8!
Dec 10, 2008 | Linksys Wireless-G WRTP54G Router
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
273 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
