Question about Toshiba Satellite A15-S127 Notebook
Screen blank the screen went blank on my a15s127 tosiba laptop after a few days of flickering. It is 5 years old now. I can see what is on the screen if I hold a flashlight up to the screen, but just barely. If anyone has a fix I would be grateful. Thank you
  • 3 Answers
The problem is likely the inverter for the LCD screen. Do a search on laptop screen repairs and you'll find out more about it. doc...
Posted on Oct 11, 2008
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
I have an Insignia flat screen, only a few years old. Screen starting flickering for a few minutes each time I turned it on, then one day it just went black. It is worth repairing?
It is worth repairing , it is a bad capacitor , take you about 10 minutes and a little soder and a sodering iron. www.youtube.com tv capacitor repair you can find video's on how to tell which one is bad , and also how to do the job
Feb 25, 2010 | Televison & Video
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Player turns on and immediately goes to a blank screen!
i had the exact same problem and that means that its just getting old and u probably need a new one
Jul 09, 2009 | SanDisk Sansa e270 MP3 Player
Laptop screen blanks out
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | EliteGroup ECS G900 Notebook
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Toshiba Satellite A15-S127 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
