Question about Olympus D-630 Zoom Digital Camera
Images appear to be very noisy or grainy
My images appear to be very noisy or grainy in appearance in the viewfinder and the resulting image. What is wrong?
    Master:
  • 852 Answers
When DIGITAL ZOOM is set to ON in the MODE MENU, the lens can zoom into the Digital Zoom portion of the zoom by pressing the zoom (T) button. When you see the zoom indicator on LCD enter the red portion (towards Tele), the image in the viewfinder will become closer. However, since the D-630 is using the digital portion of the zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This is normal when using the DIGITAL ZOOM. The DIGITAL ZOOM can be turned OFF to prevent you from using this portion of the zoom. Locate DIGITAL ZOOM in the Mode Menu and set it to OFF.
Posted on Sep 01, 2005
3 Suggested Answers
SOURCE:
neta
  • 852 Answers
SOURCE: Noisy or grainy images
When you press the “T” zoom button, the image in the viewfinder will become closer. However, since the D-435 uses a digital zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This normal when using the digital zoom.
Posted on Aug 31, 2005
neta
  • 852 Answers
When you press the “T” zoom button, the image in the viewfinder will become closer. However, since the D-435 uses a digital zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image, which is normal when using the digital zoom.
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
SPOTS ON IMAGES IMAGES APPEAR GRAINY
Is light reflections off minute dust and pollen particals in the atmosphere
Feb 19, 2008 | Olympus Camedia D-380 Digital Camera
Out of focus
If there is a diopter adjustment, for the viewfinder (to take into account a person wearing glasses) then that may have been changed and images just appear out of focus(in the viewfinder) when in reality, they may not be, if the camera is in autofocus mode.
Check these settings. Since I do not know what kind of camera this is I cannot be sure whether this diagnosis is valid.
What do the images look like when you download them?
Dec 29, 2007 | Cameras
Camera
Please more explanation - 'The ISO'
The iso related to image quality- you appear to have it set to low quality setting which gives the maximum number of images but of low resolution. Reset it to HQ or SHQ for best results.
Check your manual re how to do this.
The is usually a more comprehensive manual of the software CD in PDF format
Dec 21, 2007 | Canon PowerShot S3 IS Digital Camera
Blurry/grainy image in viewfinder and resulting pictures
This is not going to get repaired at a sensible price. Check out Kodak Technical support but I think you are looking at replacing the camera
Dec 19, 2006 | Kodak EasyShare V550 Digital Camera
Telephoto images
The D-630 has a 3x optical zoom and a 4x seamless digital zoom. In order to use the digital zoom, press the OK/MENU button on the back of the camera. Press the right arrow key to access the Mode Menu. The first setting under the CAMERA tab is DIGITAL ZOOM. Press the right arrow key to highlight this setting and then press again to select ON. Press the OK/MENU button to set the DIGITAL ZOOM to remain ON. When you press the zoom button with the T on it, a zoom indicator will display on the right side of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. When the zoom indicator is in the red zone, you are using the digital portion of the zoom. images taken in the digital zoom will appear “noisy” or “grainy” which is normal when using the DIGITAL ZOOM.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Telephoto images
The D-435 has a 4x seamless digital zoom. Press the zoom button with the T on it and a zoom indicator will be displayed in the upper right corner of the LCD. The W represents a wider area of view as you zoom out, and the T represents telephoto as you zoom closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy,” which is normal when using the digital zoom
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Telephoto images
The D-425 camera has a 4x “seamless” digital zoom. Press the Zoom button with the “T” on it, which also has the magnifying glass icon next to it and a zoom indicator will be displayed in the upper right corner of the LCD. The “W” represents a wider area of view as you zoom out, and the “T” represents Telephoto as you are zooming in closer to the subject. images taken in the digital zoom may appear “noisy” or “grainy”, which is normal when using the digital zoom
Olympus D-630 Zoom Digital Camera Logo
163 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
