Question about Acer Aspire 7720 Notebook
Hard Disk upgrade
I'd like to replace the 160gb SATA 5400rpm drive in my Acer Aspire 7720 laptop with a 7200rpm 250gb or larger drive. The hard seems to be bracketed and is not a simple "pull and remove" procedure. Any detailed help would be appreciated !!!
Thanks!!
  • fixsomething Oct 15, 2008
    The "caddy" seems to be screwed in from the top.  At least two of the screwheads are not accessible from the bottom of the laptop.
  • Anonymous Mar 17, 2014
    my acer aspire 5733z laptop reads on screen security hard disk sata 0 Toshiba mk3259gsxp lock.
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Posted on Oct 16, 2008
    Genius:
  • 2,028 Answers
I believe that the bracket you refer to, is actually the hard drive caddy. Most have a caddy of some sort, and some have it to where the caddy is held by two or four screws. once you remove the scews holding the caddy, the caddy and hard drive will slide out of the connector, and lift out. Then you will need to remove the screws holding the hard drive in the caddy, again, either two or four screws.
Posted on Aug 25, 2008
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
Can i make my 80GB hard drive to 100GB? 80GB 7200rpm SATA SAMSUNG
This is not possible, 80Gb is 80Gb and 100gb is 100gb, but I am afraid, even if you like to replace, you'll not be able to get 100gb since it's no a standard Hard disk capacity. If you are trying to upgrade, then you can find 120gb, 160gb, 250gb, 320gb etc... Good luck. Thanks for using FixYa.
Jun 06, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
What is the maximum size of hard drive for the travelmate 2300
Please keep in mind this unit uses IDE hard drive instead of SATA. The default 2300 uses a 30 GB high-capacity Enhanced-IDE hard disk. With latest BIOS upgrade, this unit will be able to have anything installed. 80GB, 160GB, 250GB, 320GB, 500GB.
However, I believe that IDE hard drives are slowly but surely becoming obsolete and legacy and they seem to be more expensive as well.
May 16, 2010 | Acer TravelMate 2300 Notebook
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Playstation 3 upgrade
Yes, you can. And Sony lets you officially do that. Just for that it has a slot on the side. You just need to remove the screw and pull out the HDD. You can then replace it with any capacity 2.5" HDD also popularly known as laptop hard drives.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Samsung 250GB HD250HJ SATA II.
Most likely if it makes sound then it is getting ready to crash, don't take a chance and remove your files and replace.
Jun 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Acer Aspire 7720 Notebook Logo
667 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
