Question about Clarion VRX935VD Car DVD Player
UNIT IS NO WORKING
I would like to know the connection for the power.
I have conneted positive to yellow ( with red marker ) and negative to black ( for testing ) and pressed power however the front panels not lighting up. Could you assist.
Thank you
  • 1,586 Answers
The yellow wire is constant 12 volts and is used to maintain radio station presets, clock, and tone settings when the car is turned off. To use the stereo, you need the red wire hooked up to switched power (so that it's got power when the key is turned, and the power shuts down when you shut off the car). That's the one that'll give you "power" to the head unit.
Posted on Aug 25, 2008
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
I LOST THE CONNECTIOS ON PIONNER DEH-2100 HOW I KNOW THE RIGHT CONNECTIONS
Red - Power - Connect to Acc on ignition or battery positive. Connected to Battery the unit will not power down when the ignition is switched off
Yellow - Memory back-up. Connect to battery positive
Black - Connect to vehicle earth or battery negative
Blue/white - Used to power up remote power amplifier or power antenna. Do not draw more than 300mA at 12V from this line
White + White/black - Front left channel
Grey + Grey/Black - Front right channel
Green + Green/black - Rear left channel
Violet + Violet/Black - Rear right channel
Use the wire with the black line in it for negative on any channel.
Do not earth any speaker wires.
RCA output jacks are used to send the output from the unit to an amplifier if you have one and cannot be used to power a speaker.
Dec 29, 2010 | Pioneer DEH-2100 CD Player
Im not sure about power wire red black ground and yellow not sure?
Connect black to earth or battery negative.
Connect red to battery positive or the acc lead from your ignition switch. If connected to acc the unit will power down when the vehicle is switched off. If connected to battery positive it will remain on irrespective of ignition switch position.
Connect yellow to battery positive for memory power. The moment this lead loses power all the settings/memory on the unit will be lost.
Leave a comment if you require further assistance
Dec 29, 2010 | Sony XPLOD CDX-GT200 CD Player
Color codes do not match my new radio can not get any power to the radio
Do these colors match your truck wire colors? Let me know if not or if you have more questions.
1991 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Oct 16, 2010 | 1991 Ford Ranger Supercab
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Cant install aftermarket stereo
The Wht/Blue wire is allways 12 volts; The Ylw/Red is switched only when the car key is on accessories.
1994 Isuzu Amigo Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White/Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/White
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Jan 04, 2010 | Car Audio & Video
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Blue (16 Gauge)
Second Ignition Positive Wire (+): Yellow/Red
Accessory Positive Wire (+): Blue (10 Gauge)
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Horn Negative Wire (-): Black/Red
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
Clarion VRX935VD Car DVD Player Logo
197 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
