Question about Gateway Computers & Internet
I HAVE A MEDICAL RECORDS BUSSINESS IN MY HOME USING GATEWAY COMPUTER. THE PROBLEM THAT I;M HAVING IS THAT THERE IS A POP-UP FROM GATEWAY TRYING TO GET TO EXTEND THE WARRANCY. THIS POP-UP IS BLOCKING MY INPUT FROM RESOUCE. i'M LOSING INPUTS EACH TIME THIS POP-UP APPWEAR. PLEASE REMOVE THIS POP-UP FROM MY COMPUTER.
  • lbwright66 Aug 25, 2008
    IF THIS WORK, I'LL THANK YOU FROM THE BOTTOM OF MY HEART AND HAVE A GOOD DAY.
  • Gateway Master
  • 6,487 Answers
If after that still have the Pop up from gateway it only means one thing you really need to gateway and extend the warranty or registration of your computer because I beliave its already expired that's why that window is alwasy coming up....
Hope that helps.........
Posted on Aug 31, 2008
  • 1,879 Answers
(If you are using a web browser for your work and the pop-up is web-based) for temporary fix : pop-up blocker (most web browsers have them)
permanent fix : call gateway to remove the pop-up (specially if that is part of bundled applications that came with your computer)
  • 876 Answers
Go to the toolbar>tools>pop up blocker>make sure the blocker is on> then down to pop up blocker settings>go down to Filter and choose High from the menu. Click Close.
Now go to toolbar>tools>internet tools>general tab and erase all cookies and temp files> click ok>Na close
I hope this helps. Your rating is always appreciated.
Posted on Aug 25, 2008
    Brigadier General:
  • 3,614 Answers
May i know the filename of the popup appear on your windows..
    Master:
  • 521 Answers
Cancel all the external settings from your pc.through clicking ---mycomputer---and properties.
    Genius:
  • 2,028 Answers
Go to filehippo.com and download CCleaner. Run the registry cleaner section of the CCleaner, and this should clear the pop up.
  • Ryan Rogers
    Ryan Rogers Aug 25, 2008
    Run the CCleaner on a regular basis and it will help keep your computer running at optimal speed and performance.
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Audio Players & Recorders
I have October 2008 unit. Just newly opened the box today. I've tried on four computers today. I'm ome tonight on a Vista Gateway. When I get ready to record the 'record' lights up and...
You need to find out what's wrong before you can fix it, so:
These instructions are for WinXP (WinVista or Win7 will vary).
Login to the system as an "administrator"
START > Control Panel > System > Hardware (tab) > Device Manager (button) >
1. click VIEW (drop down menu)
2. select "Show Hidden Devices"
3. select each USB device one by one, checking each for any entries under "Conflicting Devices,"
under the "Resources" (tab). If a device has no resources tab, then just check "Device Status"
to see that Windows thinks that "This device is working properly."
What you're checking for here is resource conflicts (DMA I/O addresses). In the case of a conflict,
you'd get "device not available or being used by another application."
May 14, 2011 | ION Audio VCR 2 PC USB VHS Video to...
Hiw do i format this phone ?!?!
how to format motorola L7 using the formatting code? can you give a formatting code
Dec 06, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Hello :), One day I turned on my computer and my network connection shows up limited connectivity now every time I turn on my computer it my internet connection shows up limited connectivity. I've tried...
if you are getting limited connectivity.. double click on network icon on task bar and go to support tab and click on repair..it will work.. if its not working give the ip and dns and default gateway manually.. not DHCP
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
Gateway Laptod Model No M360
First you will need to register at gateway, I took the serial number you provided and gateway has no record of it, once you register it, you should be able to purchase the recovery disks. I'm including the link:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=gateway&sn=0000000000 you need to register in order for this link to work, that serial number has to be in gateways system, once it is you can order recovery media. Hope this helps
Nov 18, 2009 | Microsoft Windows? Vista Home Premium...
Web Camera Driver Fail
your driver is not supported to window vista please change it and then install.It has a problem driver.
May 16, 2009 | Acer Aspire 5610-4491 Notebook
Recording in mono and not stereo
Thanks for your rapid response. Fortunately I discovered the problem and was able to resolve it. Whether it is just my computer or all computers I wouldn't know. When I switched my computer off, after recording vinyl to my pc, then switched it back on again my pc had reset the default input so I had to reconfigure it again. Since then I have not used it but wonder if I have to reconfigure the recording device everytime that I switch my computer on. I did make the USB Codec microphone my default recording device and applied the setting but the pc seemed to do its own thing.
All the best
Paul Watson
Dec 28, 2008 | ION Audio TTUSB10 Turntable
Upgrade vista home premium to bussiness edition
Upgrading from home to business edition in vista, we have to loss fewer things. Because home edition does not support for the domain functions. But its very fast and easy
here, you have a link. it may be useful for you..
http://www.microsoft.com/uk/windows/products/windowsvista/buyorupgrade/windowsanytimeupgrade/faq.mspx
Jul 22, 2008 | Microsoft Windows Vista Ultimate Edition
Dubbing vhs to dvd disc
I don't think it's the TV...IF you are recording from cable, some cable companies put out a anti-copy, or one copy only signal on some programs. It will interfer with your home usage. happened to me. I DVD'd '24' last year, and when a friend wanted to see an episode he missed-I popped my DVD in the computer, and the computer refused to burn the disk- The actual title on the disk(that I did not put there) was"COMCAST".
Jun 23, 2008 | Televison & Video
Need help printing
LMR Update: Discharge Rx Printing Increases Efficiency/Patient Safety SAFE AND EFFICIENT: To either write an electronic prescription or gain access to check the discharge medications, clinicians can simply visit the patient’s LMR, select the medication section and choose the new tab entitled, “discharge.”
Thanks to a web-based Longitudinal Medical Record (LMR) application developed at Partners HealthCare, clinicians now have the capability of printing patient prescriptions at the time of discharge from BWH.
This new function comes at a critical time when BWH is engaged in a statewide patient safety initiative geared to build awareness of medication safety, including transitions of care.
“For busy physicians, this new tool offers a faster, clearer and less error prone practice for discharge prescriptions,” said Robert G. Goldszer, MD, MBA, associate chief medical officer, who explains that this tool helps the hospital improve quality and safety
at a point in the hospital stay when a lot of information is being communicated to the patient. Additionally, this new tool allows for Partners ambulatory clinicians to easily check what medications the patient was sent home with by checking the patient’s electronic medical record.
To either write an electronic prescription or gain access to check the discharge medications, clinicians can simply visit the patient’s LMR, select the medication section and choose the new tab entitled, “discharge.” All of a patient’s discharge medications will be posted on that screen once the electronic discharge summary has been signed.
______________________________________________________
brochure printing
brochure printing
http://www.squidoo.com/brochure-printing
May 24, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Computers & Internet Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
