Question about Refrigerators
Defrost timer location
Where is the defrost timer located
  • 1 more comment
  • terriahrens Sep 04, 2008
    adaptive defrost encl part #61005988 for maytag MSD2556AEA where do we replace it?
  • Anonymous Mar 06, 2009
    i have model frs26zrg, i need to know where the defrost timer is located
  • santiagogero May 11, 2010
    Defrost timer location for White Westinghouse Electrolux WR3606D/DT 2 door.
    Nature of Problem: The freezer start to freeze for 2 days with air blowing at the compartment then after there is still ice/snow but air stops from blowing and my ice tray filled with water was not freeze.
    The same as for the refrigerant compartment it reduces it cooling system.
    Can you give me an idea where the problem are?
  • 725 Answers
Need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
fossilruins
  • 114 Answers
SOURCE: trying to locate defrost timer
on your frigidaire model, look on the front left on the bottom. for some info on your frig, see:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/95310918.pdf
page 10 item 23. hope this helps.
On the maytag defrost timer: it's probably beside the cold control in the plastic housing on the ceiling of the FF section.
Posted on Jun 08, 2008
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
Posted on May 28, 2009
TheMobilian
  • 8205 Answers
SOURCE: ATTEMPTING TO LOCATE DEFROST TIMER. DO U KNOW
Up in the console with the light bulb and cold control is that there defrost timer. Number 12
Posted on Jan 01, 2011
Where is the location of the freezer defrost timer
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
Oct 08, 2014 | Refrigerators
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge stopped cooling but freezer works what could it be
Most likely the=> WR09X10041 Defrost Timer
found inside the fresh food section and behind the control panel. Click HERE for the location. Part location number 648 is the defrost timer. Location number 618 is the=> WR51X10038 Defrost Heater Assembly
If you change the defrost heater then you should also change the WR50X10071 Defrost Thermostat
and that is the location number 620 found HERE First I want you to try turning the defrost timer slowly clockwise until compressor and fans stop. Leave like this up to about 30 minutes. You should hear crackling and sizzle noise inside the freezer. If after 30 minutes the compressor and fans do not restart this will indicate the defrost timer and that part will need replaced. Try that first and let me know what happens. I will be here to answer questions if you like, Thanks Sea Breeze
Aug 15, 2012 | GE Refrigerators
The timer is located in the fresh food section. Open the refrigerator door and look up, its in the control housing.
You can purchase the defrost timer at the link below.
GE Defrost Timer Link
Mar 08, 2011 | GE GTS22WCP Top Freezer Refrigerator
Not defrosting
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on, replacethe defrost timer and defrost thermostat. If the heater itself is bad, replaceit. Thanks and hope helpful.
Feb 14, 2011 | Electrolux ER7926B Bottom Freezer...
Where is the defrost timer located on a Frigidaire model # FRS24WNF?
its a defrost trermostat located near the evaporator coil and defrost heater coil
Oct 24, 2009 | Frigidaire Defrost Timer 215846602 ...
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 31, 2009 | Refrigerators
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost timer
Jun 20, 2008 | Refrigerators
Refrigerators Logo
2,912 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
