Question about Aloha Housewares (93645) Ceiling Fan
Ceiling fan lights won't work
We have a ceiling fan with 3 lights and 4 blades. The fan works just fine, however all three lights went out at the same time. It's not the light bulbs, we of course checked that first thing. We took it apart and all the wiring looks right. any ideas what's wrong so we don't have to buy anything new?
Thank you.
  • 89 Answers
Possibly, your switch has a short in it.Outside of that, it may be a broken wire somewhere. Hope this helps. Good luck.
Posted on Aug 25, 2008
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Remote control works the light on my Hunter ceiling fan but blades do not move
    Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
    Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
    I just installed my ceiling fan with lights. The
    Do the blades spin freely? If not, something may have fallen into the motor, jamming the blades. That would cause this. Also, make sure there is a good connection at the wire that feeds power to the fan motor (usually black, blue is the light) Good luck.
    Mar 25, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
    Ceiling fan wobbling
    put a piece of masking tape on each blade and number them.while you're up there check that mounting screws are tight.switch position of blades,i.e. move #1to #3,see if it's better or worse;switch #2 & #4 or#4 &#6 etc. until you find the combination giving you the best 'balance'
    Sep 25, 2009 | Sea Gull Lighting 1555-734 Three-Light...
    Ceiling fan/light problem
    Sounds like you have a short in the wiring of the fan or internally in the fan, it needs to be addressed ASAP as it could result in a fire if not fixed...
    Aug 30, 2009 | Oasis Hunter 54' Ceiling Fan
    Hunter ceiling fan
    Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
    Jun 16, 2007 | Hunter Ceiling Fan Control Switch
    Ceiling Fan broken
    clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
    Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
    Aloha Housewares (93645) Ceiling Fan Logo
    159 people viewed this question
    Top Aloha Housewares Dryers Experts
    Steve
    Cesar Quant
    Cesar Quant
    Mike Carew
    Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
