Question about Haicom HI303MMF-Blue GPS Receiver
HI-303III How can I turn on my GPS? When I insert it to my computer and run the Map program, the Unit doesen´t start. The LED indicator never blinks.
  • 3 more comments
  • sestradar Aug 25, 2008
    The Hicom 303III was working fine, but when I download an Map Update program, it stops working. How can I know if ny device is off? Does it have a switch?
    I can't find a power switch.
    The computer recognizes it. The Map program recognizes it at port 4, but it gives no data because it won't start. The Map program said "GPS not connected"
    The manual does not help. It doesn't describe a switch. It tells about "press Reset" but NO reset buton anywhere
    It is detected, but is like if it doesen't turns on. No data to the Map program.
    It used to blink the LED at start and stay on when working, but now LED never blinks.
  • 83 Answers
Its shod be on
Posted on Aug 25, 2008
  • soufian mankou
    soufian mankou Aug 25, 2008
    it's in the back of the unit
  • 13,433 Answers
Press or turn the power switch, il get the user manual and confirm this..
  • 3 more comments
  • Ekse Aug 25, 2008
    Led off - receaver switch is off
    led on - signal lock
    led flashing - signal searching.
  • Ekse Aug 25, 2008
    user manual is on the cd. try rotateing the receaver, it rotates. or look for a switch
  • Ekse Aug 25, 2008
    dont have the user manual to confirm how it is turned on, either by a switch or when it is used by a program - when a program tries to use it.
  • Ekse Aug 25, 2008
    look in the manual on the cd.
  • Ekse Aug 25, 2008
    It must be a problem in the program in that case, can you try reinstalling it without the update to see if the problem dissapears?
  • 521 Answers
Is it detecting.when you connect it to the computer.
  • 3 more comments
  • tech expert12 Aug 25, 2008
    step by step solution read this and solve your problem.
    Troubleshoot a GPS receiver
    This topic contains information about how to troubleshoot problems that can occur when you configure and use a GPS receiver with MapPoint.
    Troubleshoot configuring a GPS receiver
    When I connect my Microsoft GPS device to my computer, the New Hardware wizard prompts me to provide the location of the device driver. How can I find the device driver?
    If you are using Microsoft® MapPoint 2006 with GPS Locator and connect the GPS device to your computer before installing MapPoint 2006 with GPS Locator, you must provide the location of the device driver.
    To find the device driver for your Microsoft GPS device
    1. Insert the MapPoint 2006 with GPS Locator Setup CD-ROM in the CD-ROM drive on your computer.
    2. If you see the message, Would you like to reinstall or remove MapPoint 2006 with GPS Locator, click No.
    3. Navigate to D:\GPSDrvrs. (where D is the name of your CD-ROM drive.) If your computer is running Microsoft® Windows® 98 or Windows Me, open the 98_ME folder. If your computer is running Windows XP, open the NT_XP folder. The device driver has a file name extension of .inf.
    When you use your GPS device with MapPoint, it must be configured to use a COM port below 100, and a COM port of 20 or below is recommended. Devices assigned to COM ports above 100 are not recognized as GPS devices by MapPoint.
    To ensure that you have selected the correct port
    1. Connect your GPS device to your computer.
    2. In the GPS task pane, click Configure GPS to open the GPS Receiver Settings window.
    3. Click Scan to scan the ports on your computer for available GPS devices. When the process is complete, the message GPS device found appears next to the name of the port to which the GPS device is connected.
    4. Select that port from the list, and then click OK.
    please do rate the solution .thanks.keep me updated
    Complete GPS device help link.
    please do rate the solution.thanks
    have you checked the link i have provided .it will give you some more idea.pls rate the solution.thanks.
Motonav TN20 Firmware Fix
Motorola Motonav TN20 Firmware Fix
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
Motorola Motonav TN20 Manual Download
Motonav TN20 Upgrade Manual
Motonav TN20 Firmware Download
on May 04, 2010 | Motorola Mobility MOTONAV TN20 GPS...
How do i update my gps
A GPS will help find the shortest and fastest routes to a particular destination. When the maps are out of date, the GPS may not be able to find the best route. A GPS should be updated at least once per year. Some GPS manufacturers will allow the user to download free updated maps; however, many manufacturers require the user to purchase updated maps. Updating a GPS map isn't complicated, and will take about 2 hours to install.
1.Turn on the GPS and plug the USB cable into the USB slot located on the GPS.
2.Plug the other end of the USB cable into the USB slot on the computer.
3.Insert the map update DVD into the computer. If you have a map download, locate and open the file on the computer.
4.Click on Update Firmware located on the main menu. Click "OK" when the firmware is finished updating.
5.Unplug the USB from the computer and turn off the GPS. This will allow the firmware to reset on the GPS. Turn the GPS back on and select the language and time.
6.Reconnect the USB to the computer and click on "Update Map," then click on "Load Maps."
7.Connect to the Internet by clicking on the activation link. This will display the activation number. Find the serial number located on the back of the DVD. If you downloaded the update, a serial number was provided. Enter the serial number and activation code into the update program to continue updating.
8.Close the program after it has completed the update, and unplug the USB from the computer and the GPS. Turn off the GPS to finish the update.
I hope you find it very helpful. Thank you for using fixya.
Aug 20, 2011 | GPS
Map updates
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website:
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Sep 19, 2009 | Garmin nuvi 260W GPS Receiver
Own a Garmin NUVI 260W gps. How can we update this with new map, etc.? thanks.
How old is it and have you updated it once, if so
you might have to buy a update
Jun 23, 2009 | Garmin nuvi 260W GPS Receiver
Unit indicates mapcard not inserted properly but it is
card is possibly blank send it back. buy a marbella altina Nextar are unreliable GPS If in Australia see www,
e3ven outside australia the maps are available for all countries and the unit is reliable and easy to service, also has a mkap backup service if registered.
Jun 20, 2009 | Nextar X3-03 Car GPS Receiver
GPS Error Message on Start Up Model GM-7-1
sounds like your firmware or sd card is corrupt, unfortunately this is common on these. I created a dvd with the map and program data to reload everything in your unit, it also updates the map data to the last version issued. you can find it in ebay by searching for finedrive 400 map...
Jun 01, 2008 | Fine Digital FineDrive 400 GPS Receiver
Error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
Apr 13, 2007 | Magellan eXplorist 200 GPS Receiver
SC card
I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
Mar 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Haicom HI303MMF-Blue GPS Receiver Logo
122 people viewed this question
Top Haicom GPS Experts
Will Halftowaite
Are you a Haicom GPS Expert? Answer questions, earn points and help others
