Question about Bunn NHB Coffee Maker
Temp. I have a bunn pour o matic commercial coffee maker. if I pour water into it the next day I have to pour two pots in order for it to work. It appears as if one pot evaporates over night how can i turn down the temp. to stop this from happening?
  • 876 Answers
Occasionally with a Bunn you have to add some extra water. Remember when you first got it and you had to add water so that the tank is always full? It may be also that you need to turn down the temp. I need your model number to look for your manual, unless you have your manual? That is where we are going to find the answer. The model number could be on the back but it may also be on the bottom. Let me know.
Posted on Aug 25, 2008
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
Need the back switch that turns the pot on to brew(carlingswitch) for model NHB
For Service Contact:
Bunn-O-Matic (800) 352-2866
They call it "Vacation Switch"
I work on commercial equipment (including BUNN), and they don't use any names like this one in the commercial line.
Jan 14, 2011 | Bunn NHB Coffee Maker
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Pour in one full caraffe of cold water when the machine is not switched and cold.the water immediately runs out. The switch on and it keeps on boiling. Should it not switch of when temp. is reached. Model... From what I understand the swithc is to stay on at all times unless you are going to be away for awhile. The water you are pouring in will be the reseve for the next pot. I'm not sure if it should be boiling but check the filling instructions from above . I had no idea how to fill as mine was bought used. Good Luck! God bless!
Feb 14, 2010 | Bunn Pour-O-Matic VPR
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
Nov 04, 2009 | Bunn Pour-O-Matic VPR
Inconsistent water amount being dispensed
It sounds like there is some build up in the brew line, find the nearest bunn dealer and get a delimming spring, then remove the shower and run spring through brew line.
Apr 26, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
Hope that helps, and thank you.
Mar 19, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
75 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
