Question about Fisher and Paykel GWL11 Top Load Washer
Hall Sensor Fisher & Paykel mw051
Good day,
Wondering if you could help me locate a hall sensor for my fisher & paykel mw051. Any help would be appreciated.
  • 639 Answers
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Here is a good parts discounter we use. If in stock they ship quick .
Please give me a good rating before you sign off fixya.com
Posted on Sep 02, 2008
Dishwasher shower error f1 at end of cycle and sometimes e1 and e2 at start of cycle and need to unplug and restart to get working
E1
The flood sensor in the base has been activated for more than 20 seconds.
E2
The controller has not sensed the motor rotating.
Foreign object has jammed the rotor
• The rotor has failed
• hall sensor or wiring fault at the hall sensor or controller.
• The hall sensor has failed
• Motor stator winding or connection open circuit.
• The electronic controller has failed
You probably need to remove the drawer and check for signs of a leak to start with.
Sep 09, 2014 | Fisher and Paykel Dishwashers
FISHER & PAYKEL dd24 , i CHANGED THE ROTOR MOTOR BECAUSE OF THE F2 CODE AND IT WAS BURNT, BUT THE CODE STILL POPS UP AT START UP ?
Need to clean the pump sump and the drain sump to make sure there is no debris left. Most likely a bone chip or seed inside the channel connecting the two sumps. Use a thin rigid wire to clean.
Feb 27, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
Having problems with fisher&paykel mw512au washer stopping mid wash
Fault code 240 is RPS
240.
(11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 20, 2012 | Fisher and Paykel Washing Machines
Dishwasher DD605 f2problem motor has been replaced
Hi.
F2 means "Motor rotation not sensed". If the motor has already been replaced , then either the hall sensor that detects the rotation is not working, the rotor is jammed, the control board is defective, or there is a wiring problem.
• Foreign object has jammed the rotor.
• The rotor has failed.
• Hall sensor connector or wiring fault at hall sensor or controller.
• The hall sensor has failed.
• The electronic controller has failed.
• PCB mains filter has failed.
Feb 05, 2012 | Fisher and Paykel Dishwashers
What is the purpose of a hall sensor in KitchenAid drawer dishwasher?
this is a fisher paykel make .the hall sensor measures the speed of the rotor to determine that the pump is primed and the water level is correct.rotors go bad all the time hall sensors don't .hope this helps please rate my response :)
Dec 09, 2009 | Dishwashers
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washer repair.
Hall sensor may be damaged on the motor or the control isn't sending voltage to the motor
Sep 27, 2007 | Fisher Paykel EcoSmart GWL15
MW051 -U
hi craig Doctr here. there should be a hex head shape on the white knob. get you spanner or socket onto it. give it a crack. will have to check tomorrow about the thread. i can provide you with a new hall sensor. phil
Jun 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Gw709
yeh pete .your hall sensor is corroded. unplug the power lead, tilt the machine back & look underneath. unscrew that large white knob & the motor will basically remove. then you will see a small electronic card attached to the windings of the motor (hall rotor sensor). unclip it & unplug. it will be corroded. replace it & reassemble as it came apart. br phil . aussie
May 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
138 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
