Question about Nikon D40x Digital Camera
Shutter error my camera's getting a error and won't take pictures. i looked inside and behind the mirrors there is something wrong - not sure how to describe it - there's three panels and their not lined up right. any ideas as to how badly it is messed up and how much it might cost to have it fixed?
  • sharalyn602 Sep 02, 2008
    Error Press Shutter Release Button!!  I have the same problem.....worked great for a year up until this morning!
I am going through the same problem it cost me $143.00 to fix got it back took 5 pics and it started with the same problem. My camera is only 14 months old. I am now getting the run around from Nikon.
Posted on Aug 27, 2008
Why would my Auto focus mirror not folding up completely.
The mirror is designed to fully swing from top to bottom with out any interference unless something was jammed inside. If you are shooting with the lens off and watching the mirror only partially open something is jammed and needs repair. To test this put the camera in Manual mode ( M on the mode selector dial) Set the shutter speed to 1/4 of a second and press the shutter button. Having a slow shutter will allow you to see if it is fully opening and closing.
If you are making this assumption based on seeing images that have only a portion of the frame exposed, then the most likely scenario is you are taking pictures with the flash on at a shutter speed greater than 1/250 of a second. This causes the flash to fire before the shutter is fully open and therefore only part of the frame is exposed. Google "Shutter Sync Speed".
Good Luck
Feb 27, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
I just got a Nikon D7100, my shutter stays open on
Sure you did not turn the dial to mirror up?
Always chack all settings on the camera, if something unexpected happens. Like you can press the shutter release button and it won't take a picture. You left the dial in the setting for remote release. I can't believe there is anything wrong with the camera. Just a setting.
Oct 20, 2014 | Cameras
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
I own an Olympus Evolt E-500. Unfortunately, it was dropped and landed on the corner of the case near the battery door. The camera turns on, lcd screen, flash, and shutter seem to work, BUT pictures are...
I found this camera available for purchase as brand new for $450. Spending nearly $300 to repair an older version may no be a wise choice. You may find there is a market for the camera in its current non-working condition on eBay.
With that said, to your questions. 1) It will be difficult to diagnose without seeing it, but I have a suspicion in mind.
The viewfinder picture is actually what the lens sees, bounced up via mirror to a prism that projects the image to the viewfinder. If the mirror has become dislodged and is stuck in an odd position, the image would not be projected in the viewfinder. You can see the mirror when you remove the lens from the body. The mirror should be centered in the opening but at about a 45 degree angle. If it is loose or otherwise in the wrong place, this could be the problem. If the mirror is stuck and preventing the image in the lens from projecting on the sensor (behind the mirror) no capture will be possible. Other than the optics inside the lens and the mirror, there are few parts that could obstruct the image in the lens from reaching the viewfinder. Is the aperture of the lens open? If not, there may not be enough light to see the image in the viewfinder. This would also indicate that the lens is not opening up to let you see, and may not get set to the correct aperture when taking a picture. The camera usually opens the aperture to allow you to have a nice, bright image in the viewfinder. When you press the shutter release, the lens stops down to what the program says (or your manual selection) and the mirror lifts up out of the way, and the shutter fires.
2) Can you fix it? Maybe. Again, without seeing it - its hard to know for sure what the problem is and I don't know your level of skill either.
My suggestion is to bypass the camera shop that "doesn't know what the problem is but will fix it for $270" (how is that even possible??) and deal directly with Olympus USA Service and Support by phone or email to get an estimate / factory trained tech perform the repair.
Mar 08, 2012 | Olympus EVOLT E-500 Digital Camera
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
Oct 04, 2011 | Nikon D100 Digital Camera
I have a Nikon d50, had it since 2006, I took a picture, heard a weird noise, and now the viewfinder is dark as if I have a lens cap on (I don't!) I took off the lens and saw inside the body of the...
Inside the camera is a mirror which reflects the scene up to the viewfinder. It flips out of the way when you press the shutter button. When the mirror flips up, the shutter opens and exposes the sensor. When you look inside, if the mirror is stuck in an up position, you will not see anything in the viewfinder. However, the mirror is super not touch its surface or try to force it.
Sep 10, 2011 | Nikon D50 Digital Camera
I have a constant error message displayed. The
I have the same camera, but never had this problem. I think there's something wrong with the shutter mirror or worst, the sensor. Did the viewfinder blacked out when you press the shutter? I think you need to bring it to Nikon repair shop....
Oct 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Everything is dark when i look through the viewfinder
it may be a battery , or stuck shutter.
remove lense and look inside mabe give some things a wiggle. make sure you have a full battery that you know works.
if your not sure and it is a valuable camera , take it to a service guy :-)
May 04, 2009 | Minolta Maxxum 400si 35mm SLR Camera
I touched the black ribbon/fabric behind the mirror.
Unfortunately, what you touched was the cameras shutter. You will have to send the camera for a shutter replacement. You need to contact your dealer or the camera manufacturers support in order to find out where to send the camera.
Normally, a shutter replacement cost around $200, depending on make and model.
Hope this helps,
Jan 17, 2009 | Canon Digital Rebel / EOS-300D Digital...
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Nikon D40x Digital Camera Logo
27 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
