Replace the small signal board. You can usually get replacement small signal boards from www.tvrepairworld.com
SOURCE: Panasonic 52lcx65 52in projection tv
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
SOURCE: picture no sound
If you will look I bet you'll find a switch on the back of the TV for internal or external speaker. It's probably gotten switched to EXT. somehow.
SOURCE: sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
SOURCE: I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
