Question about Sony XM-SD22X Car Audio Amplifier
I need he;p!!
How can i find out the size of my amp?
  • 363 Answers
Width (mm) - approx.
403.0
Height (mm) - approx.
55.0
Depth (mm) - approx.
277.0
Regards,
Martin
Posted on Aug 26, 2008
What size power lead amp - vdc do I need for a sca 900 amp jumpstarter?
wires and cable clamps are size rated in ( awg wire) size , for example a 1/0 cable can safely handle 170 amps on 12 volts dc (car battery) , as this also happens to be the size of most all auto battery clamps and cables for most cars , I invite you to google a awg wire table for its power carrying ratings to see what size cable you need for your power pack(note look for one that's rated in 50 volts or less that's also called low voltage or class 1 )
Jan 14, 2016 | Vehicle Parts & Accessories
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
I need to know how long of a belt I need if I bypass the a/c pulley on my 2004 taurus 3.0
Ron a tape aruond it & get a belt one size bigger & one size smaller to see which one fits & return the others.
Aug 15, 2014 | Cars & Trucks
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
Amp blowing fuse when keyed up mic
what size fuse are you using? take the wattage / voltage = amp size you need.
ie... 12watts divide by 12 volts equals 1 amp.
or 60watts/12volts=5amps
but this is a estimate range. theres always surge amps that can be added etc..
rule of thumb.
40ch only types need 2amp-5amp.
the export styles and SSB40ch will need 5amp -8amp
Dec 31, 2013 | Radio Communications
What size fuse do I need on the power cord from the battery to the amp? thanks
It depends on the size of the amp. The best route to take is to purchase an amp installation that includes the power and ground cables, RCAs,remote turn on wire and...fuse holder with fuse. You choose the amp kit base upon wattage ofthe amp and they come in 0,4 and 8 gauge sizes.
Sep 23, 2010 | Legacy Audio LA930 Car Audio Amplifier
Need battery size for 1996 Dodge Caravan
your cars battery might only need charging or battery acid replacement, but if you'd realy wish to buy new one, buy one with the same size and voltage and amps as the one you have right now, or you could buy a battery with the same voltage with a higher amppere-hour (Ah) rating!
May 21, 2009 | 1996 Dodge Caravan
Need size of battery for 2000 ford focus
Dependant on engine size and fuel type, any size from a 390 amp battery, if it is diesel then a 590 amp battery. No special tools needed, only a small ring spanner. Make sure yyou disconnect the earth lead first. Also you will need to enter the radio code after changing batteries
Apr 05, 2009 | 2000 Ford Focus
Size of fuse for Ultimate PA2204
O SO U JUS NEED LIKE A FUSE THAT IS ABOUT 20-40 AMPS
Mar 20, 2009 | Car Audio & Video
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Sony XM-SD22X Car Audio Amplifier Logo
42 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
