Question about GE WSXH208A Front Load Washer
Bumping on Spin Cycle
My washer is thumping and bumping at the start of each spin cycle. The problem is getting progressively worse.
  • Cathyy Sep 22, 2008
    Final spin cycle sounds like an airplane propeller! Makes so much racket, we had to turn it off.
  • 876 Answers
Front Loaders do n ot do so well on smooth, shiny or soft flooring. they tend to jump all over the place on the spin cycle.
There are some things that you can do to improve the situation.
I learned this AFTER I paid for a service call on mine.
We placed a commercial style rug with a thick rubber backing all the way underneath our machine. You can buy the smaller ones usually at hardware stores.
Also, be very selective about loading. Wash towels with towels, and shirts and undies together, and jeans all together. In other words, no mixed weight loads.
I know this is a frustrating problem, but this hints will help. Good luck to you and thank you for using Fixya. Your rating is always appreciated.
Posted on Aug 25, 2008
Durning the spin cycle, the washer is jumping all over the place
One or more of the suspension springs have failed. Here is a link to the spring.
Take a look at this video.
Oct 15, 2012 | Whirlpool ATW4475VQ Washer
Washing machine make a bumping thumping sound at the start of every spin cycle, regardless of the size of the load (can be super small light items even)
This could be a transmission problem at the worst, if its the old style direct drive there are 3 bolts that hold up the transmission, if they loosen it could make that noise
Sep 21, 2011 | Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
GE WSXH208A Front Load Washer Logo
64 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
