Stephan, repeat what you did before. Except, this time leave the hose disconnected for 5 minutes, before reconnecting it. Also, open the tank valve VERY VERY SLOWLY (Slow motion, slow) until it's fully open. Then light the burner farthest from the tank first and set it on HIGH. If it lights and the flame height looks correct, light the remaining burners the same way. If all the burners lit and the flame heights appear normal, you solved the problem. ALWAYS, open the tank valve very, very slowly.
If the above didn't solve the problem, then you will need to replace the grill's Hose/Regulator Assembly. You can pick one up at any home center or hardware store that sells grills & accessories for about $30.00. Be sure to take the old one with you for comparison purposes.
Hope this helped you and Happy Grilling!!
