Whirlpool LEQ8000JQ Electric Dryer Logo
Posted on Jul 04, 2011
The fuse on my dryer keeps blowing. WHat could be causing this? Will dry 2 loads of clothes then the fuse will blow. Have replaced tne fuse 4 times and continues to happen. Have disconnected the dryer from the vent, and cleaned all areas where lint can collect.
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 28, 2007
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Anonymous
  • 447 Answers
  • Posted on Nov 19, 2007
SOURCE: Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Anonymous
  • 3587 Answers
  • Posted on Apr 25, 2008
SOURCE: clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
rdial54
rdial54
  • 14 Answers
  • Posted on Sep 03, 2008
SOURCE: dryer will not dry cloths
Did you check the relay switch?
Tyler T
  • 35 Answers
  • Posted on Oct 13, 2008
SOURCE: noisy dryer not drying clothes, water found in vent tube
You either have a restriction somewhere in the venting which you say you have already checked or maybe a bad blower (fan). it may be stripped off the shaft and not pulling any air through the machine. If you run the dryer with the hose removed at the back and it dries well you have a problem with your venting. If it still takes three cycles it's a problem with the dryer. Repair would probably run about $100-150
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Dryer stops while cloths are still damp
Hi
Electric Dryer---
Hope this helps...
Daniel
Are there fuses in the dryer? Not getting hot. Could it be the heating element?
Hi
Electric Dryer---
Hope this helps...
Daniel
My dryer is making too much noise and it's not even drying up clothes.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Hope this helps...
Daniel
41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
Dried a load of clothes and put another load in and now it's not working. Timer is clicking, but when I push the start button it does not kick on. Tried different settings and still nothing. It's been...
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 • Dryers
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Kenmore eletric dryer model 11064642400 bad odor
The moisture may not be getting out of the dryer quickly enough.
LONG dry time is an indication of a clogged or restricted exhaust. Inspect the hose in the back to make sure it is not crushed or kinked. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
Remember..the purpose of the dryer vent is to get rid of moisture. If the moisture can't be removed quickly....the clothes will take a long time to dry, no matter how much heat there is....
Cleaning kits are available at most home improvement centers. or at this website: www.linteater.com
Jun 23, 2008 • Dryers
Dryer wont dry
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
