Question about Saeco Easy Espresso Machine
Metal shards in hot water
When I run hot water from my machine there are small shards of metal that come out. What could be causing this.  I have been keeping up with the cleaning and descaling regularly.
  • 876 Answers
I would save the shards, package up the machine and take it back to the seller. If you don't have your receipt, credit card receipt, take a copy of your check, anything.Take pictures of everything and write down everything that you do and date it.
Be insistent with the seller and tell them you expect them to back up the product s they sell. they may or may not cooperate. It is a situation where they and the company are susceptible to a lawsuit, so you can be pretty confident here.If you have had it for awhile, then call the manufacturer, tell them your problem and that you expect immediate refund for this dangerous piece of equipment
saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: info@saeco-usa.com
Visit the Web: www.saeco-usa.com.
Good Luck to you. Thank You for using Fix Ya. Your rating is always appreciated.
Posted on Aug 25, 2008
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
The water is running very slow coming into the washer, both hot and cold
this is caused by a bad mix valve -- the mix valve is the small plastice valve that the two water hoses connect to on the back of the machine. turn off the water lines, and remove the two hoses, now remove the back panel from the machine. the valve is held in place by one small screw, lable wires hot and cold ( to make install easier ) -- remove the valve and take it down to your local appliance repair shop and buy a matching new one. install and hook everything back up and all should be good and working proper.
c...
Feb 02, 2011 | Kenmore Washing Machines
Cannot produce steam
The machine have a separate heating system for steam than hot water for steam. The steam system it might be full of scale. If you hand are good you can easily remove top panel and side panel. You can follow the teflon pipe from the steam wand and it will lead you to the steam solenoid valve and the small copper steam heating system and desasemble it both the valve and small boiler and remove any scale and dirt from it using a wire brush, shurp screwdriver and similar tool. Then poot them back together. You can try the machine with panel removed so if it needs something more to try once more again. One small tip advice. Use your camera and make pictures of everything before desasemble them, then you are safe if you forget about something. In this way you can clean everything metalic that the water pass though.
May 11, 2010 | Saeco Vienna De Luxe Espresso Machine
1 year old Frigidaire front loading washing machine will only
Check the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Pay particular attention to the hot water side. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the valve assy will need replaced. I'll attach a photo for reference. Hope this helped and best wishes.
Oct 07, 2009 | Washing Machines
No hot water is entering the machine, only cold. We have hot connected and the tpas work & are not blocked
Oct 03, 2009 | Hoover Washing Machines
Does this washer even have a hot water cycle? There is a hot water hose going in and it is turned on......but how do Iget a hot wash?
If the hot water is not working, then check the water inlet valve. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the valve. Pay particular attention to the hot water side. Make sure the screens are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter and check for continuity. A lack of continuity will mean a bad solenoid and the assembly will have to be replaced. I'll attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | Amana NTW5100TQ Top Load Washer
After initial start up on hot water , it reverts back to cold water only. The water valves work when tested in diagnostic mode.Fault reads Hot and Cold Water Valve Faulty.On hot water only it starts out...
It's most likely the water inlet valve solenoids. Be sure to unplug the machine. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. Also check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. I will attach a photo for reference. Hope this helped and best wishes.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Jun 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Kenmore oasis long fill
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Saeco Easy Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
