Question about Sony XM-SD22X Car Audio Amplifier
What size amp is this - Sony XM-SD22X Car Audio Amplifier
  • 81 Answers
  • 1200W max power
  • 200W x 2 RMS into 4 ohms
  • 500W x 1 RMS into 4 ohms
  • Variable 50 - 300 Hz low pass filter
  • 40 Hz EQ boost
It is stable to two ohms.
Posted on Aug 31, 2008
What size power lead amp - vdc do I need for a sca 900 amp jumpstarter?
wires and cable clamps are size rated in ( awg wire) size , for example a 1/0 cable can safely handle 170 amps on 12 volts dc (car battery) , as this also happens to be the size of most all auto battery clamps and cables for most cars , I invite you to google a awg wire table for its power carrying ratings to see what size cable you need for your power pack(note look for one that's rated in 50 volts or less that's also called low voltage or class 1 )
Jan 14, 2016 | Vehicle Parts & Accessories
Would like to know what electrical amps this travel trailer uses at camp sites
Sure would be helpful if you'd say more about the trailer... like what MAKE of trailer it is, what YEAR and SIZE of trailer it is... but never mind that. SIMPLY LOOK AT THE PLUG. IF IT IS A BIG APPLIANCE SIZE PLUG WITH FOUR PRONGS, IT IS LIKELY A 50 AMP PLUG, AND IF IT IS A BIG APPLIANCE SIZE PLUG WITH THREE PRONGS, IT IS LIKELY A 30 AMP PLUG. If it is a regular size three prong plug (like you'd plug into the wall), it is a 15 Amp plug.
May 11, 2015 | Cars & Trucks
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
What size of a subwoofer can this receiver handle?
any size your room can handle. The 503 has a pre amp output for a subwoofer, meaning the receiver/amp doesn't power the subwoofer. Most home theater subwoofers are powered, meaning they are a combo sub, amp.
The size of the subwoofer should be determined by room size, and space restrictions where it is going.
Dec 17, 2010 | Onkyo TX-SR503 Receiver
What size fuse do I need on the power cord from the battery to the amp? thanks
It depends on the size of the amp. The best route to take is to purchase an amp installation that includes the power and ground cables, RCAs,remote turn on wire and...fuse holder with fuse. You choose the amp kit base upon wattage ofthe amp and they come in 0,4 and 8 gauge sizes.
Sep 23, 2010 | Legacy Audio LA930 Car Audio Amplifier
Enable mini browser
Hi friend,
At the start screen, select Menu -> Call History -> Minibrowser calls and one of the following options:
Last sent browser data:—View the size (KB) of the last sent browser data.
Last received browser data:—View the size (KB) of the last received data.
All sent browser data:—View the size (KB) of all sent browser data.
All received browser data:—View the size (KB) of all received browser data.
Last browser session:—View the duration time of the last browser session.
All browser sessions:—View the duration time of all browser sessions.
Clear all browser logs:—Select OK -> Yes to clear all browser logs.
Thanks,
Dec 09, 2009 | Nokia 6015i
For an 3 Tn unit- single phase- 220 V a.c and gfor
There should be a full load amps or rated load amps on each of these units on the rating or nameplate. The ampacity or fuse size and wire size, which I think that's what you are wanting to know . The fuse size would be full or rated load amps times 125% and the wire size depending on the length of the run, 50 feet or less, (15 amps 14 gauge wire), (20 amps 12 gauge), (30 amps 10 gauge), and (40 amps 8 gauge).
Aug 11, 2009 | Heating & Cooling
Sony XM-SD22X Car Audio Amplifier Logo
94 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
