Question about GE Kitchen Ranges
WHEN TURNING ON MY OVEN THE TEMPERATURE CAN ONLY BE SET FOR 350 DEGREES. I TREID SEVERAL TIMES BUT IT WOULD NOT CHANGE TEMPERATURES
  • 639 Answers
Hi msan46,
Happy to help you!
If it is 10 years older or more, I would not recommend investing a lot of money into repair!
I think that this problem will be solved only by service!
Try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 25, 2008
Oven temp can be reduced but not increased
Bake at 350 degrees? Oven temperature is uncontrollable ...
www.slate.com/.../bake_at_350_degrees_oven_temperature_is_unc...
SlateAug 8, 2012 - Your oven may say 350 degress, but can it be trusted? ... over their hot boxes, but the dials still typically only offered low, medium, and high settings. ... It's not particularly surprising that this development came when it did.
Why You Should Stop Worrying About Your Oven ...
www.thekitchn.com/why-you-should-st...
Apartment Therapy's The KitchnAug 14, 2012 - If you fret over the accuracy of your oven's internal temperaturereading, you're working too hard. ... If that all sounds like cause for worry, it's not, and here's why: the ... low (under 275 degrees); moderate (between 275 and 350); high ....It's certainly possible to cook without temperatures, but one will have ...
temperature - Glass Dish Baking Temparature - Seasoned ...
Dec 14, 2015 | Cars & Trucks
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
I have a Maytag Gemini range and the bottom oven is off by 25 degrees. When I set it for 350 it only gets up to 325 actual temp even though the digital display says 350. Is there an adjustment or do I have...
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
