Question about SanDisk Sansa Clip MP3 Player
My sansa wnt work!
Wen i put in my computer and it was working and i played some music and then wen i jus pull it out of the computer it wnt turn on anymore...
  • Anonymous Aug 25, 2008
    i added new music to my sansa clip unplugged it & it will not turn on.
    help
    Tried to put music on my sansa clip and unplugged from computer. Now it turns on and freezes at the begining of on mode just says sansa san disk and stays there
Me 2 mine wont work either!!!!!!!!!!! wot the hel do we do!??
Posted on Aug 27, 2008
902 wnt turn on bt lights activate
make key pad lights light up (turn on) and leave it like that mine dus it then turns on after 30 secs ,,,,my speaker wen i play music distorts wen turned over half way could you solve this. thanks
hope it helps
Aug 26, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
IT TURNS ON BUT WONT PLAY MUSIC
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 03, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sandisk Sansa e260 gone retarded 4.0GB
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 28, 2008 | SanDisk Sansa e260 MP3 Player
My sansa c250 music folder is empty
Actually after some searching it is VERY easy to manage the c250, you just have to know how to connect it. You must connect it to read as MSC format. To do this, put on the hold feature and press and hold the rewind/previous track button as you connect it. This will open it up as a removable disc. So just drag and drop whichever songs you want from the MUSIC folder. You may also delete individual songs that are already on there. Hope this helps, works for me.
Fox
Mar 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Nothing happens when I click on Menu button
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Start the computer program before you plug in the View??
Jan 20, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
My computer wont recongnise my mp3 player
Do you have another PC to try your mp3 player ?
Jul 06, 2007 | SanDisk Sansa c150 MP3 Player
My sansa wont work HELP PLZ
Ok, I have a Sansa e250 2.0 BG. I have an extra memory card but w/e thats not part of the problem. So, when I downloaded music, I accidently put more music on the Sansa memory and it made it too full. So now it has to do a system restart everytime I turn it on. Which is really annoying. And then I tried to delete some music so It would stop doing that and I could update it, But it shows up on my computer as there being no music. So theres nothing to delete! But it says the memory is full! HELP!!!!
Mar 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
