Question about Pioneer KEH-P2030 Cassette Player
Where can i get a removal tool? - Pioneer KEH-P2030 Cassette Player
  • Pioneer Master
  • 5,013 Answers
Ebay or your local Car Radio/Audio Store
Posted on Jul 05, 2011
SOURCE:
Replacement right rear passenger hand operated window have broken window can't get window handle off
U need a special tool to remove handle. There is a clip and this needs a tool that will push the clip off and allowing u to remove handle.
May 10, 2018 | Cars & Trucks
Which tool should I used at the time of moving?
You may use following removals Tools
  • Moving Dollies
  • Pallet jacks
  • Hand Trucks
  • Hydraulic Tools
You may also get information about Removals Tools Here
Removal Companies Tools
Apr 02, 2013 | Measuring Tools & Sensors
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
Licience key for ms removal tool
You can download the license key at this link: http://warebuzz.com/downloads/ms-removal-tool-license-key-forum.html
Enjoy :)
May 29, 2011 | Acer Computers & Internet
I need to remove my 6 cd changer am fm radio how does ut come out please help so i can replace it
you need the radio removal u shaped tools. you can buy for $5 at uto store.
SECTION 415-01: Audio Unit 2002 Escape Workshop Manual
REMOVAL AND INSTALLATION Audio Unit
Special Tool(s) s2k~us~en~file=st1445a.gif~gen~ref.gif Radio Removing Tool
415-001 (T87P-19061-A)
Removal and Installation
  1. Disconnect the battery cables. For additional information, refer to Section 414-01 .
  1. Remove the audio unit.
    1. Insert the special tool into the radio face plate and release the radio retaining clips.
    1. Pull outward on the special tool and remove the audio unit from the instrument panel.
  1. Disconnect the connectors.
  1. To install, reverse the removal procedure.
Apr 22, 2011 | 2002 Ford Escape
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
Removal & Installation
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
Cannot find Webroot to remove - conflicts with Mcafee install
check under programs if it is installed it should be there
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
I need to remove the radio in my 1998 mountaineer
you need specail radio removal tools. they spread 4 spring clips.
  1. Remove the radio chassis.
  2. Insert Radio Removing Tool into the radio face plate and release the radio retaining clips.
  3. Pull outward on Radio Removing Tool to remove the radio chassis from the instrument panel.
Special Tool(s)
Radio Removing Tool
May 12, 2009 | 1998 Mercury Mountaineer
Wacom pen won't respond on desktop or internet webpages
Hi, this is how to remove application's specific settings:
"REMOVING APPLICATION-SPECIFIC SETTINGS  To remove an application-specific setting:
1. In the TOOL list, select the tool from which you want to remove the application-specific setting.  Then, in
the APPLICATION list select the application you want to remove.
2. Click on the APPLICATION list’s [ – ] button.  In the dialog box that appears, click DELETE to confirm your
selection.  The selected application is removed from the list, along with any custom tool settings that you
may have created for it.
Hint: To quickly remove all application-specific settings from a single tool, remove the tool from the TOOL list.
Then place the tool back on the tablet.  The tool will be added back to the TOOL list using the default settings."
Apr 23, 2009 | Wacom Intuos3 Graphic Tablet
Removing norton ghost before reinstalling
If you tried removing Ghost yourself by deleting foulder or files then it will not appear in the add/remove list. Try reinstalling it and then using removal tool. Make sure you have correct one for version and your OS. My advice is stay away from Norton products, they severely slow down performance and hinder daily activities. There are free tools online that work much better.
Dec 30, 2008 | Symantec Norton Ghost 14.0: Windows
Pioneer KEH-P2030 Cassette Player Logo
102 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
