Question about Whirlpool Duet GHW9150P Front Load Washer
Duet lock is locked without door being closed.....nothing works now....is there a simple solution?
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Try unplugging the washer for a couple of minutes! if that dose not work it's a failure and you need service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
How do I get the Whirlpool washer door to close all the way? I think the door lock is jammed
The lock/latch on your door is electromechanical, incorporating a electrical safety catch. See if a reboot (unplug for 10 minutes, then plug it back in.) does anything for you. It could be a latch, wiring, motherboard, door closed safety circuit or something in the pause circuit.
Jul 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet HT. The control lock botton is on. So the washer will not start it does nothing. I unpluged it, hold in the unlock door botton nothing works. The door opens and close I just...
Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked. If this was helpful please rate me Thanks :)
Jun 12, 2011 | Whirlpool Washing Machines
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Control locked
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. You also cannot unplug the washer to reset it. The Control Lock can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
