Question about Zenith XBS344 System
DVD Eject tray stuck
The disk tray won't open. There is no disk stuck in there. When I press the eject button, the words "load disk" light up and I can hear the tray trying to eject, but it never does. Then it will say "no disk" after a few seconds and not do anything else. THe DVD eject tray is stuck on my system as well. I tried putting in a VHS and then hitting open and that didn't work. And I can't seem to find a system reset button. Any help is very welcome! thanks!
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Posted on Jan 07, 2009
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
Optical drive tray is open, can't close - disk is stuck inside my notebook
Power it down and if you look very carefully, near the eject button is a hole.Insert a straightened paper clip and the drawer will open. Unless it is a Mac.
Nov 09, 2013 | Computers & Internet
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
My computer dvd wont open
Look on the front of the tray where the eject button is There should be a small round hole, this is for ejecting a stuck disk. Just open out a paper clip and insert in to the hole and press until the tray opens.
Jan 31, 2012 | Lite On Computers & Internet
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Will not eject disk.
Almost always, your described problem could be caused by:
  • stuck disc;
  • fault in the load/eject mechanism.
It it were a stuck disc, the correct fix would be to open the unit and manually extract the erring disc. However, there may be possible workarounds:
  • unplug the unit for an hour or so;
  • press and hold the eject button while plugging in; or
  • invert the unit (bottom side up);
  • plug back the Apex and quickly unplug soon as you hear the mechanical noise start;
  • revert to normal position and try ejecting; or
  • while still in the inverted position, press and hold the eject button while plugging in but must unplug quickly even before the tray starts to move out.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2010 | Apex Digital AD-1225 DVD Player
Zenith XBS344 System Logo
1,180 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
