Question about Cameras
Sony DCR-HC 36E On video recording image appears OK and all seems tp be recording well, display normal. However when playing back the image appears in bands of the currently recorded video with alternate bands of the previously recorded video. Is this a menue feature or has the camera a problem & how do I rectify it?
    Master:
  • 521 Answers
No its not a menu feature.its a faulty lens just clean the lens.or the battery is old.change the battery.
Posted on Aug 25, 2008
  • 13,433 Answers
Can you clarify what do you mean with bands. Have you tried reseting the camera to default settings that can be done either in the menu or there should be a reset button.
  • Ekse Aug 25, 2008
    The video heads may be dirty use a cleaning Casette to see if things improve
    http://www.sonystyle.com/webapp/wcs/stor...
    there are some special effects you can turn on and off in the settings, but as you reseted the camera they should be all OFF
    There is a reset button / switch. I suppose you have found it.
  • Ekse Aug 25, 2008
    there is a MOSAIC FADER setting in the camera.
    also if you record in the LP mode, a mosaic like noise may appear in the video or sound may be interrupted when you play back the tape on other devices.
    if you mix with SP and LP mode, the picture may become distored.
Would like to record in 16:9 ratio but am not sure of the results? goof or bad?
You may record in either wide-screen or normal mode. If you record in wide-screen mode, the video will appear compressed when played back on a normal TV. For full details refer to the "Using the wide mode" section of the manual on page 32 of the manual.
May 03, 2012 | Sony Handycam DCR-TRV525 Digital Camcorder
I have DCR-HC 36E and as the PMB given as an alternative for Windows 7 comes with an ilink connection which is not there i n my computer. is there any USB driver for this camcorder.
This solution is only applicable for the selected camcorder models. You can follow the steps mentioned below for the DCRHC36 models.
  • Turn on the computer.
  • On the computer, install the USB driver from the CD-ROM supplied with the camcorder.
Only the USB driver included on the supplied CD-ROM will properly enable the camcorder for USB streaming. The USB Streaming Driver can only be installed from the supplied Software CD.
  • Turn the camcorder on to the PLAY/EDIT mode.
  • Turn on the USB streaming feature in the camcorder menu. P-MENUPICT.APPLI.MenuUSB SELECTSTREAM
  • Connect the USB cable to the camcorder.
  • Connect the other end of the USB cable to the computer.
  • Cue the video to the beginning of the video footage to be transferred.
  • Start the video capture software on the computer. You can try Software like Windows Movie Maker
o NOTE: The computer must have compatible video capture software to complete this procedure. Many video editing software applications include a capture function. If you have video editing software, you might not need a separate video capture application.
  • Begin playing the recorded video in the camcorder.
  • Begin importing the recorded video with the capture software.
Good Luck
FixYa
Nov 19, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
I have sondy handycam hc-36e but while runing the picture package showing error " to run this application, you need to install macromedia flash player first"
If Macromedia Flash Player 8 is installed on a computer where no previous versions of the Macromedia Flash Player have been installed, then the Picture Package Menu option may be unable to start. To resolve this issue, download and install the Picture Package Menu update from the Picture Package Web site at: http://support.d-imaging.sony.co.jp/www/disoft/int/pixela/picpac/dl/dl_ppk_menu1x.html
The issue should be resolved.
Jan 15, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony DCR-HC 36E Bands of old video & pixellation
well, first a few things I want to point out to you.
-fixya is no a job for experts.
-I can't be on guard 24/7
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=1551&storeId=10151&langId=-1&productId=11027631
Aug 25, 2008 | Cameras
Sony DIgital Handycam DCR TRV110E 3 solid bars across image
your heads need to be cleaned with a cleaning minidv tape. about $20 for one of them, otherwise you will need to fork out a bit of cash to get the heads replaced... probably better jut buying a new camera - a hardrive one!
Nov 04, 2007 | Video Cameras
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony handycam DCR-HC-32E records only in blue and red
the ccd image sensor is the problem of your camera....it have to be replace with the new sensor....i do not know if it is still free for replacing the sensor but the model of your camera is one of sony the recall product....because the ccd image sensor have a factory error..
Aug 01, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
