Hi Crushed ice is delivered by turning the motor in a clockwise direction, and cubed ice is delivered
when the motor turns in a counterclockwise direction.You need to check and make sure that the auger motor reverses direction(as above). You could have a problem in the crushed ice switch, wiring or auger motor. Under the ice tray or compartment is a wire shaft which runs to the control unit. Check to see if it is bent or obstructed by any object underneath it. If not then it is more than likely the control module selenoid located where it goes into the control housing.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
