Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
Temp Bought A used Kelvinator chest freezer. What should temp be? If I barely turn it on it goes to 20 degrees. Whats a good temp for this type of freezer?
  • Anonymous Sep 06, 2008
    My chest freezer does not have a readable temp gauge - Model # MFC05M1BW0 Kelvinator...Thermostat I set on the turnable knob to the "dot" in the middle between Minimum and Maximum...Is that the optimal setting?
  • 639 Answers
Jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Meat along the outside seems to be thawing out.
HI, If you want the temp warmer, move the control to the smaller #'s
If there are no #'s, turn the control clockwise and see if it shuts off. if it shuts off, that is the right direction for warmer temps.
I hope this helps you. please let me know.
Vic
May 31, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezer stops and start
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
189 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
